Cr 125 idles high
My cr won't idle down below about 1/4 I've put a new air filter on and looked at the carb (had it off inspected) looked ok it runs fine but is overheating now I thinks it must be running lean but the air mixture does nothing with adjusting (no obvious differance) PLEASE HELP!!!!
Also when I give a little throttle or a lot it takes a while to go back down
Head gasket most likely replace that and it should be fine happens to my mates Kdx 200 a few times
What year cr? How do the carb boots look. What did the reeds look like when you pulled the carb. How many hours on the bike?
Check for air leaks or a bad crank seal.
Spray wd40 or other on the carb boots while the bike is running and listen for changes in rpm
It an 03 reeds looked great the boots are also good I clean them off when I took the carb off no cracks or anything. It also has all new gaskets ever were, and was just rebuilt with about 8-10 hours on the new top end.
Edited by Shoodong
WD40 will soften and swell rubber so i would suggest using that.  Carb clean or starting fluid.
A top end rebuild wont take care of crank seals.
Does the air screw on the carb change the idle at all?
