07 crf 250r who needs parts?
IMG_5088.jpgforks $200, seat $40, plastic set $90, front and back wheels w/ sproket and tires $350, swingarm $100 rear shock $70, dual exhaust $100 fork tree $40, front brake assembly $40, carb $150, radiators $50, gas tank $70, camshaft $100, stator cover $50, clutch cover $30, frame $200, subframe $70, kickstart lever $45, shift lever $15, new clutch lever with hot start and perch $30, New brake lever w/ perch master cylinder and caliper $120, and any parts for engine let me know cause i will have to see if they are ok because the motor locked up and broke the cases so alot of stuff is messed up inside.
Seat has small tear in it I repaired but you can still see where it is. I haven't looked at it but can I take that hose off the brake perch or do you want the whole brake assembly
Caliper and all
