SM-To E(?) conversion.
Long time lurker, first time poster!
No where near my first bike, but def. my newest bike.
I've had my 08' 400-SM for about a year now, and bought it for a fun, city-bike to drive back and forth to work/play.
Well, I'm looking to transition into more dirt riding with it now. I had a street-legal Yamaha TTR250 years back, and did alot of dual-sporting/long rides/camping trips with it. Looking to set my SM up the same.
My biggest thing is the wheel/tire situation. I'm (idealy) looking for a second set of dirt rims, as I have a brand-new set of tires for 18/21's
All I've been able to find are new sets for $1000+ Not really wanting to drop $1000+ on some dirt rims. And everytime I catch some on ebay, it's when I've not a penny to spare (of course, LOL).
Now, I'm not opposed to the ideas of:
1) Picking up a set of 17'' dual-sport tires from http://www.procycle.us/bikepages/drz400.html#wheels
Though, I'm not sure how they perform..
2) Trading my SM wheels for some S (or E?) wheels.
But I'd imagine I'd have to relocate the calipers?
What about the gear-ratio? Are they pretty close? For off-road, I'd like to get something a little lower-geared.
Anyways.. I've browsed the forums, and I've only been able to find little snips and pieces here and there.. Only people looking to convert TO an SM model, not the other-way around.
I'm going to keep searching, but if there is anything else that I should be aware of, I'd greatly appreciate it!
Also, I'm in the Dallas area, so if any other DRZ guys out this way, give a hollar!
Thanks!
Not really sure wher the question was.  SM to S conversion is common.  Use E or S wheels (the same).  Keep your eyes open, sets come up for $600 to $800.  Use the SM brake disc and no caliper relocation needed.  Use a S speedo drive.  Gear to suit, it is always a compromise. 14/47 is E gearing. 15/44 was S gearing.  Something in between will probably work.  If you do not need the SM wheels they can be sold for about the same as the S/E wheels cost you.
If your going to sell the sm wheels let me know.
Thanks!
it's easier to sell the bike and get an S.
less easy = shinko 244's
still less easy = change out the rotors, gearing, to a new set of 18/21", and still have those purdy USD stanction tubes waiting to bump a rock and dump all your fork oil, and that huge front rotor (rock, again), and the reduced suspension travel
even more of the less easy = exchanging short SM forks and shock for longer S forks and shock
really, you should give shinko 244's a shot first. if you -like- off roading, then look into an S model. the narrower front wheel (and rear) makes for much better handling off road, and hopping logs are cake.
Long time lurker as well...
I just recently did what you're hoping to do.  Found a set of S wheels (ebay for roughly $550), installed a Kenda 760 Trakmaster on the rear and a Pirelli MT21 on the front.  Left the gearing and front rotor stock.
After riding the trails once, the only change I've made is swapping out the rear sprocket for a 44 ... much better (tempted to try a 47 however I think then the chain will be too short).
Not sure what to do about the front rotor as it does provide more than enough braking, and, I sometimes wonder how long before it gets dinged.
Hope that helps a little
I have an sm with both sm and s/e wheel setups and have had no issues with suspension or the front rotor. I run 15/48 for dirt and 15/44 for sm both with the same chain. Would like to go 14/48 or 50 for a bit more grunt. I have had the bike in some pretty tight situation through rocks mud and trees with no issues so far. Not sure how much of an advantage switcing to an s model would be.
if the chain is stock length, 15/41 and 14/47 should fit, no issues. the 14/47 will be much closer to minimal adjustment, the 15/41 around 1/2 way through the adjusters. i don't know if there is a trick to quickly adjust the slack on a SM swingarm, for the S/E/K it's just a quick number change on both sides. ideas for the SM guys ?
I picked up a set of zeta axle blocks. They are longer on one side so you can flip them and get some more adjustment. Still cant fit 15/48 and 15/41 on the same chain... that would be ideal
could you post up a link to the axle blocks and stuff, so future kids can see em ?
if you swap to 14/47 on the dirt wheels, they should fit with stock chain, and it's a better DS (not interstate!) ratio anyway. :)
http://m.ebay.ca/itm/200909085730
There you go. I got the red but you get the idea. I don't like the idea of changing front sprockets often. I plan on putting in a set of wide ratio gears in so that I can go lower on both sets and still go on the freeway with my sm wheels.
I'm looking into doing the same conversion. Will the stock spacers from the SM work with 18/21 S wheels?
yes
I'll trade plastics with you if you want to go all out :D
