oil filter o rings- what goes where?
Been taking my filter out to check for shavings- last time doing it I noticed that the small o ring is missing. After looking at my Clymers and schematics online I really can't tell where the smaller one goes. Does it go on the end of the filter or around the lower bolt on the removable filter casing?
Try the I believe the oring goes between the cover and case . Around the bottom screw which is shouldered . There may even be a slight recess in the case or cover .
