2013 CRF 450 Radiators
Last weekend i got tangled up and ended up on the ground, i thought that i just bent one side of my radiator and started to fix it for the next moto, upon further inspection i noticed that my forks fit my radiator guard on the other side too so i knew it got bent too, my question is if somebody can get me a picture of what the distance is between the radiator and frame close to the radiator mounts thanks
Here you go, not sure if they will help or not.  2013 CRF450R.  Note my left Radiator was replaced with Mylers so the cap is different and the braces are beefier.
The left rad on my '13 just started spontaneously leaking (no crashes and no visible roost damage), so I ordered the Mylers. What were your experiences installing it? Was it a bolt on replacement for the stocker, or did you have to modify/adapt anything?
See my other post :-)
http://www.thumpertalk.com/topic/1037904-2013-crf450r-left-radiator-replacement-with-myers-supercool
Two things:  1) Everything lined up but you'll need a different slip bolt.  2) Before re-attaching the rubber dampers, I would try sticking them on temporarily first then put the radiator on and see where they hit the frame.  I thought I put them in the same spot, measured and marked with a sharpie, but they were off.  Had to take them off and re-apply.
thanks, can i get a picture of the top mount on the right side if your sitting on the bike like a picture directly down the frame above the gas tank
As good as I can get without taking the tank off.
