Clutch lever irregular feeling
Last day, The clutch feel like sleeping for a 4 laps heat, I reajust the lever but now, the feel in the lever is like irregular, like notchy.
Oil only have 4 hours, clutch 15 hours and the trouble isn't the cable or the lever
My bike had 125 hours and the outer and inner basket get some notch but I ever see some more notched going well
Some sudgestion ?
Did you swap to the 2009 cable/lever arrangement? I think you had posted in my thread about it.
I had the same kind of problem and it was 100% the stock cable routing, IMO if you have aftermarket exhaust it will cook the cable in no time.
Could also be a notched basket, worn plates, sheared oil, etc.
Depending on how/where you ride, 4 hours might have cooked the oil already.
Some guys take out the judder spring and put in a stock plate for better clutch feel but I don't think that it makes the clutch feel "notchy"
It's the cable, disconnect it and try and push-pull it from the engine side you will notice a lot of resistance.
