400EX bottom end
I've heard of some guys swapping out 400EX bottom ends to get electric start, but that the gear ratio is different and it also has a reverse gear.
How exactly does the reverse gear work? Does it replace 1st with reverse, like you click down to go into reverse?
How different is the gear ratio? Good/bad for street use?
Thinking of doing a big bore and either swapping in a 400EX bottom end or just the crank part.
I just used the crank and gear from the trx had to spilt the cases anyway and I heard you need to move mounts to fit a trx bottom end.
Oh I thought it bolted right up. Definitely will just do the crank and starter then.
