Fork swap with honda or?
I have an 06 rm that has a scratch on the right tube. I want to find another one that will fit. Are any of cr tubes the same?
I am also wondering if the lug offset and clamp dimensions are the same.
Forgot I had a set of 2004 CRF forks in the shed.  Mic'd the upper and lower clamps and took a look at the lugs.
The upper clamp dimensions are different.  The RM forks are almost 3mm larger in diameter.
The lower clamp dimensions are the same.
The lug offset is significantly pulled back on the RM.  Somewhat hard to compare the offsets at the triple clamps.  I sure wish there was some database of clamp/lug offsets for all OEM bikes.
