Oil streiner bolt
Hello I live in Italy.
My question is this: to change the oil I take the allen bolt near the gear pedal also the bolt under the engeno and the the little cover screw that is also for cecking the valve. My problem is I always get 500 ml out and when I put the new one it takes the same amount. I can not take the streiner bolt (if that is the right name ) out it seems to be welded and now the head is starting to get rounded. Is that why I can not get all the oil out and what should I do for that bolt?
On mine that bolt every time I take it out it feels like it won't come out but with some.force always comes loose.
Make sure you using right size wrench. That strainer should b cleaned every couple oil changes at least.
Break in I would do every time for first 10 he's.
Maybe I'm over precautions but I clean every oil change takes 5 min why not do it.
Might have to drill it put and get a new bolt
If it's already starting to strip it's going to be hard to get it off. Mine did the same thing, tried to use one of the special bolts to cut new groves and get it off but that only made things worse.... In the end I had to use a screwdriver and hammer to force it to back out... Might want to go ahead a buy a replacement bolt so you can replace it once you do get it out.
I had the same bolt problem.....
I got out the bolts that hold the motor on the frame(I left only the rear bolt), so i can move the motor a little down and the steiner bolt would not be behind the frame.
I fit on the streiner bolt a T handle 12mm or RATCHET SOCKET 12mm(don't know if this is the right name).... and then i try to hold it with as force i could get to it (as much it didn't get of the bolt) to counterclockwise and my friend hit at the T handle with a hamer (at the top of the tool) with small quick hits and the bolt loosen up easily.
I was holding the T handle all the time to counterclockwise.
I do it every change but that bolt scares the crap out of me. I order replacements after it starts to wear and will continue to do so. For 9 bucks it's just so much easier.
I rounded one off so bad once i used huge channel locks and it did the trick.
Please can you tell me how and where can I order one.
hello
I got a new one for the price of 33 euros. I know it sounds crazy but the only place I could find it here in Italy online was for that price.
Now I need to know if some else can tell me a mothod for taking it out. I don't care at this point if I wreck it.
hello
