2007 KX450F Timing Chain Jumping Teeth
Replace the cam chain it is probably worn.
Or if recently replaced then check the chain tensioner is working properly and holding tension.
New timing chain is a must.
Hold the tensioner in your hands, and wind it in, while holding the ram back. Then gently release the pressure on the ram end and ensure it moves out smoothly and holds firm. If you suspect the slightest problem with it, then replace it for sure.
If any teeth on the cam spockets look damaged, then replace the cams. They are under $100 each.
You just cannot risk not doing these checks on a 4 stroke.
Though the timing chain may need to be replaced this sounds more like a tensioner issue. Make sure the tensioner is operating properly by removing it and inspecting it thoroughly.
I popped a new chain in and checked the teeth and tensioner. She started third kick and purrs like a kitten. Thanks for all the help guys. Sorted!
