Hydraulic brake switch
Has anybody had any issues with hydraulic brake switches suddenly not working? Or should I look elsewhere for the culprit? The tail light still works but no brake light.
a tester is your friend
but try the front and rear brake to see if the bulb illuminates in either situation this can help isolate   and confirm the bulb circuit
If you have an air bubble in the brake system, it increase the amount of brake pressure required to activate the switch.
A jumper wire between the two sides of the switch will tell you if the problem is the switch.
Edited by heart_of_darkness
how do I do that? Do I just jump the two wires and press the brake and watch the tester?
Hydraulic switches seem to have limited life expectancy.  Rockymountainatv has cheap replacements.  You want one for a Japanese thread spec.
that's a sweet deal considering I just paid $24 local, bonk! I think I'm gonna order an extra for those long rides next season.
