rear brake caliper compatibility between other Yamaha bikes & years?
Does anyone know or have personal experience with the rear calipers on the yz's?
I have an 08 yz 250 and need a new rear caliper.  My rear caliper has a ton of play side to side and I am not sure a rebuild kit will cut it? Prob easier to just buy another caliper/
Does anyone know if say all the rear brakes on Yam offroad bikes were the same from x year on? Or do you know if a 20xx yzf/wr 250/450 rear caliper is the same or compatible w/ my 08?
Thanks all.
I have a rear caliper from 07 yz250 two stroke
If you are interested send me an email
cardioto@aol.com
Thanks all.
Following list is compatibility of YZ rear brake calipers.
Rear caliper itself : 06-13 YZ125/250/250F/450F, WR250F/450F
Rear caliper bracket : 06-13YZ125/250, 06-08YZ250F/450F, 06-13WR250F/450F
But, it will be repaired with the exchange of rubber boots and slide pins.
5UN-25914-00 .pin, slide
5DH-25914-50 .pin, slide
3JD-25917-00 .boot, caliper
1UY-25937-51 .boot 2
Thanks a ton guys!
