rebound needle jammed in shock shaft
This is a showa shock from an XR600, with separate adjuster rod and needle.  The rebound clicker wheel and the adjuster rod are removed from the shaft, but the needle doesn't want to come out.  The needle moves up and down slightly.  Is there some trick?
