RMZ 250 2013 SFF
Hi'
i need your help
i have RMZ250 2013 model with the sff forks
i'm 80kg
i can't find good setup for my bike :banghead:
can you help me please???
thank's
So you weigh 175lbs.. ok, now we need to know what skill level are you and what type or riding you do as well as what is your environment like?
i'm 42 but still beginner....
most ride mx most mid jumps about 20m
track on mid/soft land
thanks
try that stack:
32.15x14
29.15
27.15
25.15
23.15
21.15
20.15
midvalve
26,15x2
24.15
22.15
20.15
18.15
15.15
with 0.35 float
rebound
26,10x8
14.10
24.10
22.10x2
20.10x2
18.10x2
16.10x2
14.10x2
drill the piston 1.5mm bleedhole
cut the spring seat 4mm.
oil level
280cc cartdrige side
310cc spring side
clicker setting
rebound 12 click out
compression 14 out
preload with spring seat cut 14closed from full open
Put all settings in the middle.. I can't remember all settings so hopefully if I am wrong someone will correct me.. so on forks you will have a total of 26 clicks of compression.. and 24 clicks of rebound.. put the comp/rebound at 12 clicks out. Then I think the preload has 36 clicks. Put the
Preload at 18 clicks out. Then rear shock has total of 24 clicks of compression and 24 clicks of rebound.. once again put them at 12 clicks out.. now you will be on stock settings. Start from there and make adjustments.
Once you have tried these settings holla back. Give rider input, and we will go from there.. P.S. make sure your fork height and race/static sag is correct before tuning ok..
Also turn the high speed comp on rear shock all the way in and turn out 2 turns.. this high speed comp has 4 turns of adjustment
thanks
i will try it !
do you know how to set the front sag ?
