2013-2014 KX450f Fork Stacks
Just wanted to know if anybody could verify if they are the same, and if this is the correct stock base valve stack for a 2013 KX450F KYB PSF. The guys at Techincal Touch USA we nice enough to send me what they have as the stock base stack which is listed below.
26.11 (12)
24.11 (8)
22.11 (3)
20.11
18.11
16.11
14.11
12.11
11.11
I have a used set of  2013 forks, and it only had one 24.11 shim instead of 8. The previous owner had the forks were previously revalved, so its possible they were removed.
I also did a search on the forum, and another member posted only one 24.11 shim too, so thats what has me confused to what stock actually is.
So what is the stock base valve stack?
That looks stock. I'll check my notes, but that looks to be stock bv setup. On the bleed stack there should be five face shims, then taper.
Thank you.
That is the stock BV stack for a 2013 KX PSF fork, less the bleed stack of course.
Thanks,
Rob
