How can i bring a PC works pipe back to its original state?
So I have heard that steel wool and wd40 can bring a works pipe back to life....? what is something you used to get the rust off? It doesn't look rusted to me...looks....burnt...I mean it was ridden hard....
Wire wheel, then wet sanding 100-600, heat up the seams with propane torch to bring back the original hue, then apply penetrating oil while it's still hot. Looks better than new.
+1
Put WD40 on after every ride, and wash, to keep the rust at bay. Its a nice pipe, but requires maintenance.
thank you so much will do ill get back in a bit with pics when im finished!
yup I bought it like this id die if I dropped 250 in the pipe it and it started to rust....  thank you!
ImageUploadedByThumper Talk1383369759.623336.jpg it's an fmf but I used 4 aught steel wool and wd40 and this is how it came out. It took the "factory" color off and left just the shiny metal but it doesn't look bad!
wow that looks awesome...did you heat up the seams to get them blue?
nope they just turned out that way I guess. It took about half an hour of scrubbing!
