Upgrade 09 or buy leftover 2013?
My dilemma ( see above)... My 09 has about 50 hours on it, engine is solid, it's due for a fork rebuild and that's about it ,
I am not thrilled w/ the handling either, may put on some offset clamps to remedy ( $400).
My queston is do I do the upgrades ( about 700) or fork over 5500 for a new 13. Is there a noticinle difference between an 09 and a 13? I could get about 2400 for my 09
Thanks
My opinion isn't worth much cause I've never ridden an 09. The 13 is a sweet handling bike that doesn't need much chassis work at all. It will pull a little better than a stock 09 due to the larger carb and some small engine changes. Is that worth $3000 to you?
Unless you are an A level rider it probably won't make you much faster. And if you are A level you should get a 2014.
