Break in period for a new drz 400 motor
So I smoked the motor on my drz and its finally operational again. I have the break in paper from suzuki, and its says 500 miles on 1/2 throttle and 500 on 3/4. My question is if I ride on the highway 60-70mph am I good or am I gonna cause dammage?
Highway riding is not the go for break in.....steady throttle with minimal load on the engine is the worst thing I can imagine for a rebuilt engine...,(that is next to running it without oil)...
my suggestion is to "head for the hills"...
Some will say to baby it,  some will say to ride it like its a ''REAL E'',   not sure whats better,  but i think most will agree on changing the oil at 100 miles,  then 300,  then 600,  and then the regular 1K oil change intervals should be fine.
Congrats on getting your bike going again,  what happened to your engine?  did you go BBK or stock?
Heavy acceleration and deceleration
Don't lug it , thrash it , let it get hot .
yep heavy accel and decel is ideal for performane but try and include a few coasts and idles, the aim of the game is to get the motor to see as many vibration modes as possible whilst being as lubed as possible and focussing on your own specific needs (in rpm that is).
to be honest, if you sat at a single rpm you will not do damage but after all the work it will inhibit performance (head pressure).
ive seen many theorys on engine break in, by far the best ive heard is ride it like you would normally, the engine will wear to suit.
Some mates of mine ski race, they build the stock motor up to spec without running it then take it out and thrash it, motor never sees low rpm so they say why brake it in running those low rpm. obviously this is an extreme case but you get the point wear it how you want it to be ridden
and yes as backyard hack said let it get hot. the cylinder expands more then the piston.
I said Don't let it get hot ...( as in too hot )
Edited by backyard hack
Any half throttle babyit too much breakin , I did that in 1984 and never again, oil burner. I do believe you have less than 100 miles to do most the ring seating.
Presently the last few bikes Ive used a 300 mile breakin and all have been long life motors with no oil burn issues (40,000 on drz and over 100,000 mile on VFR as an example(no oil use, and no problems), but just use the full rpm range with strong burst of accel and decel, but dont stay anywhere for too long(seconds), yet dont go into the last 20% of the upper rpm scale, till you get to the 300 mile mark, then let it rip and do a full extended top end run. Dump the oil and ride, a full cool down between a couple of sessions is ideal too.
Keep in mind every bike Ive broken in, the first filter is never the worst(its normally the best). The 2nd filter is normally the worst the bike ever sees.
Edited by Spud786
do stop/go city riding, lots of heavy acceleration/ deceleration (engine braking). if it's not still smoking in 5 miles, it's broken in. if it's still smoking at 500 miles, well, i guess keep riding.
and riding. check back in 30,000 - 40,000 miles.
Google 'Mototune'
Your engine is fully 'broken in' in during the first fifteen minutes of runtime.
I broke my Eddie built engine in on the Dragon.  Haven't had any issues and it pulls like a beast.
Dragon ?
I would follow the mototune way. Ride it hard through the gears, lots of engine braking etc, change the oil and filter after 30kms.
Dragon ?
think he's talking about deals gap.
Dragon ?
US129
Yes, that Dragon.
These are filters taken from my new Yamaha 660 Ténéré after the 100 - 200 - 500 first km oil changes. Don't wait to change the oil/filter, there's a lot of crud swimming around in that first oil you don't want to see getting into your bearings and other machined surfaces.
That's a very alarming and true illustration of what's spinning around on a new engine....
I agree it's important to change out oil and filter 2 or 3 times in the first several hundred kilometers..
