Carb Help
Does anyone run this carb?? If you do, does it run lean for you??  I start my bike and after a minute or so at idle the pipes are glowing red.  The carb is a Sudco TM Series Flat Slide Carb.
Usually pipes glowing is an exhaust leak if not running rich and an exhaust leak. Unburnt gas moves through the motor, hitting the hot pipe which with a leak mixes with that air and ignites. Are you experiencing any popping?
Otherwise i am unfamiliar with your carb.
Good luck!
EZ
