How do I set my timing
Set your piston all the way up at the top of the cylinder at top dead center and the cam should have a mark on the sprocket that lines up with a mark on the head.There should be a timing plug on the same side as the gear shifter of the engine.pull it and you'll have a line or  T that will tell you when your at TDC (top dead center) with the piston.
