Setting timing on my Klx110
So I took the head off of my klx110 for the first time to send it out to have some port and polish work down. My bike is a 2010. Problem is, i was reading instructions from a 2009 and older. Now my problem is, I took the head off while the piston was not at TDC. When I go to put the bike back together, how can i be sure that the timing is correct?
put the stator to TDC once you're putting it back together, make sure the cam loves are pointing downwards in opposite directions(valves are closed) and then set the cam chain to the cam sprocket, be sure the small symbol on the cam sprocket is at the top once it's at TDC.
