KTMfinrider
Common failure with ktm300, leaking "oil" from power valve linkage cover?!
My 2017, with about 100 hours, hasn't seeped a drop around the pv. In fact, the whole motor looks like new except some boot wear on the sides. And whatever coating they're using on the cases works, cuz it's less boot wear than you'd expect.
Hey guys
i own a 300 17 model mine leaks from the pv cover and the cover on opposite side but thats not as bad, just wonderibg if anyone has a solution ive tried everything
replaced the D shaped orings one was completely worn down due to vibrations
replaced inner clutch cover gasket
replaced the pv gasket numerous times with different sealers ect
changed the pv orings
nothing seems to stop it and im all out of ideas
Ps my bike runs great not too rich ect , i believe the oil leaking is engine oil not oil leaking from pv
any help would be greatly appreciated
9 hours ago, Rexy said:
Hey guys
I used blue RTV on my 17, seemed to work.
Are the bolt holes blind or do the bolts see pressure from behind? If the holes are not blind you should seal the threads with either RTV or some Permatex thread sealant
I think ive tried every sealant besides that , how badly was yours leaking ? And did you use it on the D orings?
As far as i know they are just straight into thecylinder head there should be no pressure behind but ill double check
Posted (edited)
Well come to think of it, it probably doesn't need a lot of pressure..... Just exposure to the threads would be enough as it will wick up the threads with ease.
Edited by gdwrench
I will try using rtv on the bolts to hopefully seal them and maybe that will finally fix it 😫
judging by the pics above I think you'll have better luck … 😉
