kickstarter gear swap XR200
Whozaa,
I tend to wonder that even though you can get the cases together, the H/D K/S idler gear may be contacting first gear C/S where it shouldn't...........not on the intended thrust surface.
Also is interesting the area you relieved on the case is quite a bit different and less then what was required on the cases we did.
Old School Al
I examined the K/S to C/S gear fit very closely and while I didn't see any rubbing or anything else unusual, it's impossible to see inside the cases after everything is assembled and running. So I agree that it's possible that the gears will wear against each other.
Here's a detail I forgot to include earlier. :blush:
There is a thrust washer that goes between the K/S and 1st gear. This is what keeps the two gears from rubbing their faces together. The later K/S gear has a slight relief on one side. As best as I could tell from the fiche and FSM, that relief is supposed to face towards the 1st gear. However, when I oriented the gear like that, it slightly rubbed 1st gear (next to it). The relief took away the clearance that the washer setup. So I flipped the K/S gear over so that the relief faced the case instead. In my pic you can see that there is a gap between the two gears of about 1mm, the thickness of the thrust washer.
Edited by Whozaa
On 12/29/2013 at 11:42 AM, Chuck. said:
Good stuff and lots of details so time for some picture, here are two part fich pics.
Here is a 90 kick start spindle: The Ratchet Spring is #5
And a 90 Transmission: The kicker gears are #17 & #18, the bearing is #34, #3 is the CS 1st speed gear.
Hi Chuck, what parts normally are worn causing the slippage problem with the old xr kickstart?
Number 2 & 3. #5 should also be replaced with the 86+ version, or stretch the old one to increase preload. I also suggest stretching the 86+ version.
Edited by Chuck.
  • Helpful 1
   Done that. It helps.
  • Helpful 1
Number 2 & 3, #5 should also be replaced with the 86+ version, or stretch the old one to increase preload. I also suggest stretching the 86+ version.
ok 2 is the one that is not available i guess a full swap out is in order!
