How can I get better throutle response from my 450
How can I get better throutle response from my 450exc? I just road my 2003 for the first time and i had a small delay in the response. I ride mostly in Southern Ca. At an averge of 4,500 ft. What is the right jetting for my bike or what jetting do you use to have your bike in good shape? Thanks for your help. :)
It takes a little time to get the jetting perfect. Ask JD in the jetting forum for help at your altitude. The BK mod for the accellerator pump will shorten the squirt time from about 4.5 seconds to 1 second for much better throttle response. My settings are: BK mod, OCEMN needle at 4th clip, 170 main, 45 pilot, 2 turns out on screw; adjust for temperature. (Midwest altitude)
Buy the JD jet kit! I did and I'm very impressed, it works!
I even paid retail for one!!!
jet it and run the power now mod
Agree 100 %
i ve also heard great things about the icat system. I m told by my shop that it took all the jetting issues out of one of their race bikes. They say the thing rips now regardless of where they run it now.
By trading your KTM 450 for a CRF 450. Sorry man I could not resist. Seriously though!! :)
I too ride in the deserts around socal and run 42(stock) pilot 2 turns out, OCEMN needle 4th clip and 172 main. So far she's pretty good.
I am going to do the BK mod this weekend as I know the AP squirt is killing me. Hope this helps ya. :)
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
