Has anyone tried the 756RR front tire yet ?
I realize these tires wear quickly but my front tires last a long time anyways so I thought about giving them a try in an attempt to get this Honda front end to stick.
Was it an improvement over previous tires that you have used?
How has it worn?
What terrain do you ride?
Would you buy it again?
Anything else that you thing is relevant?
Not one person knows anything about one of the most popular tires out there? Anyone?
No offense, but apparently nobodys dumb enough or good enough to justify paying that much for a tire.
When I first read the post the RR didn't catch my attention. I run the standard units until I hit the lotery. Bring me up to date is the RR the unit with the stiff sidewall?
Two things come to mind...
1) the stock K490 front sucks (03 and 02 models)
2) get almost anything over the K490
That being said, if your front end is not sticking, it is most likely suspension setup or the need for linkag/clamps if you have an 02. The 03 model has updated linkage parts that change the steering angle. I personally run a Maxxis IT up front and it works awesome except in sand. I have a Dunlop 742 waiting to go on the front though to try out. Dial in your rear sag, these bikes need it "just right" to turn properly, I have found 95mm-97mm is optimal for me.
Price is not really a big deal on the RR Dunlops, if you look around, they can be had for only a few $$$ more than other models....$100 each is too much, and I feel sorry for anybody that actually paid that much for an RR model... :D:)
DOH! I see you have a 2004 model, well for sure, your steering issues are not tire related, sounds like improper setup, the 742 that comes stock on that bike is supposed to be pretty decent....
The 756RR is about $7 more than the 756 at Rockymountain. Price is not really an issue. The test I saw said they absolutely ripped (they claimed 2 seconds a lap faster)but the magazine guys are idiots if you ask me. They also said they wear really fast so I would not consider the rear just the front. My turning technique leaves something to be desired. I've only been riding a few months on the dirt and I improve everytime that I go out. Recently I rode an '04 YZF250 and the thing handled way better than my '04 CRF does and I went a lot faster thru the turns right away. He had a standard 756 on that bike.
I've got my bike dialed in the best that I know how. Whenever I lower the front end of my bike in an attempt to get it turn better the rear will not hook up. It will just slide out every turn.
I also did try a 120 the other day and it was way better than my 110 so I'll be switching that as well in the near future.
Oh that's it? I retract all statements I made. :)
Most likely the suspension for the YZ450F was setup correctly, enabling you to corner better. I would say not getting the front end to stick is not a tire issue as much as a rider/suspension setup issue.
I'm having the same problem with my front end washing. What are the possible set-up mistakes that i have? Sag or clickers? :)
I just saw/read about using a 90/100-21 front tire instead of the normal 80/100-21.
It said it acted like the 20 inchers traction b/c it has a wider footprint.
It also mentioned both Dunlop and Bridgestone.
I don't remember where I saw it though.
I don't know of one offered for sale yet either.
I ahve been running one on my YZ 250. I have ridden three times before the snow hit. The tire is wearing fairly well. It is better than the standard 756, but it is a small difference. I bought one from Rocky Mountain. No way in hell would I be willing to pay 100.00 if I went to buy another one.
I've got one on mine, but since I'm not RC, that must mean that I'm too dumb to opine on the matter. :)
What the heck, I'll risk it. It works way better than the POS D742 in my opinion, but it isn't magical. It's probably the best front tire I've ever run but by a small margin. I'll probably try another tire or two that I've been curious about before I decide it's my "new tire". Wear seems pretty close to a standard 756 so far, but this is only after 4 rides. I'll be surprised if that changes.
I'm running a 756 front on my '01 426. It's waaayyy better than the stock739, probably the best tire I've ever run to date on any bike. Part of that may be because it's a soft-terrain tire which matches my riding conditions better than the stocker. I'm going to try the 90/100-21 Dunlop as soon as it comes out. Motocross {Yamacross} Action Mag says it works pretty well.
Hi Sunhester
I am relatively new to MX/Dirtbike riding. I have improved significantly since i started nearly 2 years ago. I always thought i had a front end suspension or tyre problem but after 1.5 years of my riding budding constantly pestering me to "GET FORWARD ON THE SEAT" i can now say it was mostly rider related.
May or may not be relevant, but hopefully of some help to you.....
I run the RR on mine also. So far (only 3 rides on it) it seems worth the $$ to me. Now if it was even close to what they listed for when they 1st came out I'd say HECK NO, but for the extra 12 bucks I paid I feel it's worthy of a "give it a shot" from anyone thinking of trying it.
So go right ahead........Give it a shot! :cry::cry:
If I remember correct, you can run lower air then a stock 756 because the sidewall is constructed stiffer. Lower air = wider footprint which is some soil conditions (sand & mud??) will work better.
1-888-BSY-FAST you can get 756RR for $55. and 756 for $40.00. tell them john stinson sent you. by the way my 03 crf450 has standard 756, rr version wears too fast
gainesville fl
I though I was the only one that hated that tire more than the 739 front. :cry:
I've got a set of RRs on right now that worked killer on a very well groomed & soft track that hosts an arena cross series I did a few races on. On the hard/loose, dusty & dry tracks, the front is noticably loose. For the hard stuff, I need more of a square knobby as opposed to the RR pointed knobbies.
yea the guy i bought my 450 used the RR's. They work great, but obviously you know they wear out fast as hell. If you ride on a budget, they are a waste of money.
  • Similar Content
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By desert520sx
      I have a 03 450 that I just got and it runs great! I love my bike and am big on preventative maintenance. I have searched the threads on TT and have not found any descriptive threads on how to check valve clearance or adjust them. Just by looking at them, I can see that the intakes need to be shimmed and the exhaust valves can be adjusted quite easily unless one needs to be adjusted differently than the other.
      I tried to do it last night, and lined up the marks on each side to get the piston to TDC to check adjustments and could not get any readings on tolerances on either the intake nor the exhaust. I moved the crank a little bit forward and got a .011 reading on the exhaust valves. I read in a thread that the spec was .011" for the left one and .014" in the right for the auto decompressor. The spec I am using for the intakes is .006" Are these specs correct? :excuseme:The only issue is that the adjustment for the exhaust valves is one and the same. Different from my KTM where you can adjust each valve individually.
      No matter where the cam was on the intake valves, I could not get any readings. Does anyone have a thread, website, downloadable manual, or article on checking and adjusting valves in these beasts?
    • By Eric Schrader
      I am selling my 2007 Honda CRF 450-R which is set up for desert racing (Track/desert). It has an 18" rear tire with a heavy duty setup (see description for details). The bike screams and has a Tokyo mods carb mod with the 10x ignition mapping (currently set to a handlebar switch for smooth power and max power). Gas tank is a 3.2 gallon IMS dry break tank. V4 steering stabilizer included. Precision Concepts suspention, Bike is set up for 6'4" 175lb rider. Zero oil leaks and well maintained using a preventative maintenance method with the best new parts each time. Receipts for all items can be provided. About 20 hours on the rebuilt head. Carb just rebuilt. Starts cold in just 2-3 kicks. 100% reliable bike as long as you turn the gas on.  Current CA Red sticker and original title.
      Expand above to see details
    • By bigg_stevee
      I recently replaced water pump and seal after I noticed that my '02 CRF450R was spilling coolant on easy trail rides. After the water pump swap (which was successful), I noticed the same problem. It's interesting - the bike only spits coolant (I mean a LOT of coolant) after passing anything above 1/2 throttle. The bike makes this weird 'gurgling' noise, like trying to suck through a straw when your glass is almost empty. This is weird because I properly bled/ burped the radiators with coolant, and filled them to normal operating levels. The coolant spills through overflow hose.
      anyways - I swapped the radiator because I thought maybe the bike was running hot. I purchased oversized radiators, bought a 1.6 radiator cap (with a temp gauge) and bought engine ice. The bike runs very very cool - the temp gauge allows me to see this. Still, the bike shoots coolant out of the overflow after going above half throttle, making the same weird gurgling noise when it does. Bike has all of its power, top end was replaced not too long ago.
      I'm lost and don't know what is wrong with the cooling system in my bike. How do I make the bike stop shooting out coolant, and stop making the weird gurgle noise??? Any advice would help me!!! Thank you!
    • By Mxer59
      I have a brand new Barnett Extra plate setup still in the box. It replaces the judder spring with a regular fiber. My old clutch had a judder spring break which wiped out the stock clutch. I was in a bind ordered this kit but it ended up coming 2 days later then it was suppose too. So now I don’t need it asking $180 SHIPPED
      —“Complete Extra Plate Kit- consists of 8 Kevlar friction plates, 7 tempered steel plates and a set of springs. Provides maximum clutch capacity.”—
