drz 400 2001
Hey there I have a 2003 klx 400r and am trying to talk my buddy into buying a drz. He found a 2001 drz for a reasonable price but I was woundering if there are any differences between the 2001 and my 2003( besides the colour)? :)
is it an S or an E?
if its E,there is no real difference.
If its an S,then he is better off looking for an 02.the 01 S has crappy suspension(no rebound adj).It also doesn't have a few plastic guards that the newer ones have(engine case and rear caliper).
Just minor little changes. The bike basically hasn't changed since 2000. I'm sure other guys will give you a more detailed explanation.
  • Similar Content
    • By Supermotofool
      I totaled my DRZ400S last year, did a good bit of work to it and finally got it running.. I want to turn this into my full stunt bike.
      I have read before about people buying a 2nd stock rear caliper & bracket - then cutting and welding it to the existing bracket, then just running a handbrake master, and a hose to the 2nd caliper.
      Has anyone done this before? Defiantly seems to be the cheapest route to go (staying away from the junction valve / 1 master cyl. & 1 caliper setup.)
      Looking for opinions, pros/cons, and info if anyone has gone this route.. If it seems too much of a risk or hassle I guess im gonna have to spend the $500/$600 to get a legitimate setup
      any and all comments are appreciated - except trolls.. you better be funny as hell if your gonna troll.
      Thank you all!
       - Brad
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
