mojave riding
years back i did some riding near Randsberg moved to south orange county and haven't been back to mojave. i want to take my 10yr old (very accomplished rider) out that way and into randsberg. any suggestion as to where i should stage, cal city etc...?
You could stage at Wagon Wheel near Ridgecrest...several camping spots along Garlock Road or Cal City.
You might try posting this on the "Southwest" Ride forum. :)
Hi,
I am the president of Rattlers MC, a small family oriented dirt bike club based in the San Fernando Valley. Our club rides exstensively in the area you are referring to. Since you are traveling such a far distance, my reccomendation might be for you initially to try the Cal City area. If you want to ride to Randsburg I would camp at the location known as Camp B. If you provide me your email address I would be happy to let you know the next time our club is headed out there and you would be welcome to join us. It always helps to get the lay of the land from somebody who is familiar with the territory. If you want to travel a little farther my personal favorite area is farther North near Searles Rd. on Highway 395. From there too, you can easily ride into Randsburg for lunch at the saloon. Always be cautious of mine shafts when riding in the Western Mojave, be respectful of trail closures, and please leave your camp cleaner than you found it!! HAVE A GREAT RIDE!!
thanks for the info..i'll look up those areas.
I camp and ride in Cal City a lot and I would suggest anywhere off of 20 Mule Team Road (between Cal City and 395). Camp B is located in this area on the north side. You could really camp anywhere in this area and be fine and have privacy if you choose. Silver Saddle (I think that's the name) resort is in this area and may help as a landmark on the map. Plenty of marked trails on the north side which will help to get you to Randsburg. Like Buzzard said, watch out for mine shafts the closer you get to Randsburg. Good luck and have fun.
  • Similar Content
    • By jakebarritt
      I have a 2005 CRF450R with a Trail Tech fan kit installed. I need a little bit larger tank and would like to know if anyone has an aftermarket tank that fits with the fan kit.
      I dont need a monster 4 gallon, just maybe a 2.4 or 2.7 from IMS would do fine.  I talked with both the tank vendor and Trail Tech and neither could give me any answers.
      Thanks guys.
      Jake
      Minden, NV
    • By smythe
      Complete 2009 CRF 450r cylinder head with valvetrain.
    • By NickC18
      So I emailed Factory Connection today to see what spring rate I need for the rear as I’m about 6’2” 220 lbs without gear. I also asked for a baseline front fork PSI to start at. This is what I received:
      Nicholas,
      The spring series we made for your bike is limited when it comes to larger/stiffer rates.
      The spring rate you need is 5.9/6.0 range. We don’t sell that over the counter as it requires special installation process.  So we can’t sell the spring “over the counter”.  It would have to be installed at our shop.
      Fork PSI I would recommend:
      Inner 160 psi
      Outer 11 psi
      Balance 160 psi
      Are they blowing smoke up my ass? What kind of ‘special installation’ could a spring take? I’ve changed and removed them before but not on a 16’ CRF before.
      Also, aren’t those psi settings for the Kawasaki KYB? I don’t think the psf2 have inner/outer/balance do they? Maybe he was having a bad day...or maybe I’m an idiot. FC’s website list there spring as ALS-0059. Can I not just order this spring and install it to set my sag correctly? Help?
    • By johnsbikerepairs
      hi, i have a crf450R 2009, having difficulty setting the idle knob to factory setting.  Having problems interpreting manual Japaneses interpretation.  Can anyone out there assist with the correct factory setting and how i can manually do the setting ie how many clicks out or in etc...   would appreciate any assistance
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
