front disc brake guard
are there any bolt on guards for the front disk?
Yep, Topar Racing web page sells a 2 pc kit. You need to buy the front brake line cover/shark fin mount & the shark fin itself. $120 for the set.
The old Acerbis disco cover has always worked for me. It doesnt protect against BIG hits but for $22.00 it works just fine. $120.00 for a disc guard seems outrageous to me :)
Does anyone know who makes a plastic front disc cover for the DRZ400E? I can't find one listed on the Acerbis website.
I have seen many DRZ's with them on...
I have one made by rooster performance that is 1/4" steel I think. It has held up very well considering where and how I ride errrrrr fall.
I have a Devol Racing aluminum front disk cover on mine. it installed easily, protects well and looks great. :thumbsup:
I thought it was $83.95 for the kit. What am I missing.
Ditto. No DRZ listed in drop down.
Cycra is cheap, easy to bolt on and mine has some significant hits and no problems yet...
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
