Where/how can I buy just ONE spoke?
My local Honda shop couldn't seem to help me out- they pretty much told me I'd have to buy a whole new spoke kit. I just broke one, so I sure hope I can buy just one. They are Excell spokes for an 18" rim. I'm not sure if I need the longer or shorter spoke- I broke an inside spoke. Thanks for help.
first of all you need to find a dealer if they told you that.....go to serviceHonda.com if there is some stuff u need OEM
I think your dealership was trying to make a buck! Western honda is also a great place to order OEM parts. I keep all 4 spare spokes, all bought individually.
Part#06421-MEB-750 is the left, inner
Part#06420-KZ4-J40 is the right, inner
The inner spokes seem to break easiest, good luck! :)
Worst case, if you CAN'T find anyone that sells single spokes -
Go to a KTM dealer. Or, go to KTMtalk.com and look up a front spoke on the microfisches. KTM does sell single spokes.
Sweet, thanks. Are those part numbers for OEM spokes? I need Excell spokes for the 18" rim. That's a good idea to keep spares around. I'll probably order a couple of each. Do you think any of the big retailers (Motosport Outlet, Rocky Mountain, etc.) would sell the individuals? (too late to call tonight)
You can get the stock ones from Service Honda, but you do have the Excel Spokes so try this guys:
www.wheellacing.com
(209) 368-9800 (CA)(TRC Wheel Lacing)
or
www.eastcoastwheels.com
(908)727-0751(N.J.)
I have some spokes too(extra's).....I'll look to see what I have when the sun comes up and the kids are off to school. :D Which is it: the inner or outer on that 18" wheel? :)
Nope I don't have those ones......sorry!! :)
OK, here's what I found out. Maybe it will be helpful to someone...
I spoke with th guys at TCR wheel lacing. They said they don't use Excell spokes and that basically they are junk- although Excell is trying to make it so their wheels HAVE to use Excell spokes by sizing the nipple holes so only theirs will fit :)
TCR suggested I call Excell directly, which I did (760-732-3161). They were helpful enough and sold me some individuals at $3 apiece. No warranty on the spokes themselves.
I'm now sorry I didn't buy the Buchannon spokes. I've bent and flat-spotted my share of rims but never broken a spoke (I only weigh 155). I've had the excell spokes just a few months and already one snapped. Hopefully it's not a sign of things to come.
I'd find a new parts guy, or politely suggest he look at the quanity required column on his microfiche. Honda doesn't sell spokes in complete sets even if you want them, you just buy 32 or 36 as the case may be. Sounds like the parts guy you talked to is new to Honda and has worked in blue/green/yellow shops too long.
I found this out months ago when I was builting a wheel for a friend. Not Honda or Buchanan fit White Brothers.
I know I've said this about a dozen times, but here it goes again......Excel Rim, Buchanan Over-Sized Spokes with Spline Drive Nipples and Talon Hub. A bit of money to spend, but all cost about the same(whole wheel set-ups).
When did Excel start doing this? I've used their rims in the past on older bikes and the stock spokes fit just fine :) I will have to keep this in mind when I go to buy a new rim...my front rim is getting a lot of flat spots.
I would definitely find another shop to go to. Hasn't mattered what shop I went to, they always asked me how many I needed and is it inside or outside....although I can't say for sure about Yami/Kawi/Suzuki, I've only owned Honda's. But I've been to places like Cycle Gear and they've asked me how many, etc...these are probably better places to go anyway cause they seem to be cheaper. Just a thought.
  • Similar Content
    • By GarrettSG
      I need recommendations on Honda dealers with good Mechanics in Western Washington. I am in Puyallup but will drive for peace of mind. I have never had a dealer do major work on any of my dirt bikes. But long story short I am on a 15 CRF450R and it needs the 5th gear recall done. Any and all info is much appreciated!
    • By jakebarritt
      I have a 2005 CRF450R with a Trail Tech fan kit installed. I need a little bit larger tank and would like to know if anyone has an aftermarket tank that fits with the fan kit.
      I dont need a monster 4 gallon, just maybe a 2.4 or 2.7 from IMS would do fine.  I talked with both the tank vendor and Trail Tech and neither could give me any answers.
      Thanks guys.
      Jake
      Minden, NV
    • By NickC18
      So I emailed Factory Connection today to see what spring rate I need for the rear as I’m about 6’2” 220 lbs without gear. I also asked for a baseline front fork PSI to start at. This is what I received:
      Nicholas,
      The spring series we made for your bike is limited when it comes to larger/stiffer rates.
      The spring rate you need is 5.9/6.0 range. We don’t sell that over the counter as it requires special installation process.  So we can’t sell the spring “over the counter”.  It would have to be installed at our shop.
      Fork PSI I would recommend:
      Inner 160 psi
      Outer 11 psi
      Balance 160 psi
      Are they blowing smoke up my ass? What kind of ‘special installation’ could a spring take? I’ve changed and removed them before but not on a 16’ CRF before.
      Also, aren’t those psi settings for the Kawasaki KYB? I don’t think the psf2 have inner/outer/balance do they? Maybe he was having a bad day...or maybe I’m an idiot. FC’s website list there spring as ALS-0059. Can I not just order this spring and install it to set my sag correctly? Help?
    • By johnsbikerepairs
      hi, i have a crf450R 2009, having difficulty setting the idle knob to factory setting.  Having problems interpreting manual Japaneses interpretation.  Can anyone out there assist with the correct factory setting and how i can manually do the setting ie how many clicks out or in etc...   would appreciate any assistance
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
