02 crf450r suspension.
Hey guys. I'm looking for some info on what you guys think I should do about the suspension on my 2002 crf450r. I'm 5'9" and weigh 195lbs. I am a novice/junior rider. When I got the bike, although I found it to have really good suspension, it seems to be a little soft. MXA magazine suggested that going to .49's in the forks and 5.6 shock spring would be all I need to do to make the suspension stiffer. After looking up the Race Tech website and talking to a local suspension shop, both of them said that I would be better using the stock springs and revalving the suspension. I thought that I would like to try and revalve the suspension myself with a Race Tech gold valve kit for the forks and shock. The kit suggests changing the midvalve for a checkvalve, but after reading the comments on this site, it sounds to me like this is not a good idea. My first thought was to just change the compression valving to race tech specs without installing the check valve. Will this make the settings softer or harder? Any other suggestions would be appreciated.
if it is a little soft there are cheaper fixes than valving if you are casin your stuff eveywhere than maybe at your weight and ability you should be able to work that out with the stock stuff i will see my susp. guy tomm. 1-7 see if i can get some exacts for you
Here's my current stock suspension set-up. Forks: comp set at 2, rebound set at 9. Shock: hs stock setting, ls 10, rebound 10. I've tried running suspension settings that MXA recommended for the bike stock, but they recommended crazy soft setting for the fork in the 15-18 range. My biggest complaint is that the forks seem to hang down and wallow upon landing from a jump. I haven't experimented with the oil height on the forks yet, but I think I will try the pvc pipe trick and see if that would improve the last part of the stroke, as the forks seem to bottom really easily. I had a 2000 yamaha 426 and a revalved 98 yz 250 that did not exhibit these characteristics. Right now, I'm scared to do a lot of the bigger jumps that I used to do with my yamahas because it just blows through the stroke too quickly. I don't really have many complaints with the shock, but that's probably because I'm concentrating on the forks. I would like to try the storm link though.
The race tech stuff is good for what it is intended to; learning to understand the concept of mx suspension. That being said, I don't believe it is your best bet for performance. They recommend to disable the midvalve to a checkvalve to make their valving easy and convenient for them to make their setup easily transferrable from one brand to the other without much testing for them. But, the truth is; there are substantial gains to be had with proper midvalve tuning. Your CRF needs much work in the midvalve department and you should select a suspension tuner that does work on the midvalve also. There are quite few good ones. I know for having seen them work on my bike, MX-tech does extensive work on the midvalve and even machines part of it on a lathe. Remember, Honda stock valving must be handled by the head toilet scrubber, or worse. They don't know what they're doing...
  • Similar Content
    • By Stillwell Performance
      One of the most common calls we get here at the shop is “how do you recommend I go about tuning my suspension?” Good question! The second most common call is “I started turning clickers on the front/back/bottom/top etc. and now I don’t know what I did, help!” The amount of improvement you can gain from proper suspension setup is significant, if you go about it in the right way.
      Look at it this way: if you are 6ft. tall and get in your truck after your 5 ft. 3in. wife just drove it, the first thing you are going to do is adjust the seat/steering wheel, etc. for your size. The same thing goes for your bike’s suspension-last week we had (3) 2010 bikes in the shop for revalves at the same time. Identical models, one guy was a 150lbs. pro racing MX, the next guy was a “B” level GNCC racer and weighed 220, and the third guy was a 180lbs. trail rider. Same bike, three totally different setups!
      So with that in mind, here is where to start:
      • Grab your owners manual, a computer, clipboard and a scale. You cannot effectively start tuning until you determine if the correct springs (fork and shock) are on the bike for your weight. Put down the double cheeseburger, hop on the scale, and get your weight in street clothes. Add in for your gear, which typically runs between 20-30lbs. You can easily check recommended spring rates by visiting www.racetech.com under their spring rate calculator. Look in your manual (or ask your tuner) and see what rates are on the bike.
      • If you need to change spring rates-do it first. Trust me on this, trying to tune suspension with the wrong rates is not only frustrating, but you will be short changing yourself on the results. On most bikes the shock spring is easily changed, fork springs can be a bit more difficult-get qualified help if you need it.
      • Even if you are familiar with what “clickers” are, take a moment and read your manual. Determine what style of forks you have (closed cartridge or open cartridge), where the compression and rebound clickers are, and check to see if your shock has both a high speed and low speed compression adjustment.
      • Grab the right tools to adjust, load up and go find a typical piece of terrain to test on. By typical I mean your MX track, hare scrambles course or favorite singletrack. You don’t need to ride a 30 mile loop in order to adjust your bike, rather focus on finding a section of track/trail that has all the different types of jumps/bumps/whoops you encounter.
      • OK here is where I will preach a bit-everybody has a buddy or two that claims to “know suspension” and setup. This is YOUR bike, and unless you plan on dragging him around on the back of the seat the end result of your tuning should be focused on what feels good to YOU. Trust the feedback the bike gives you…..
      • SET YOUR RIDER SAG!!!!!!! This is critical to tuning properly. Again, look in your manual or ask your tuning dude.
      • If you do not have an idea of where to set your clickers, put them in the middle of their adjustment range. This is your baseline setting.
      • Gear up and get warmed up. It is important to be loosened up on the bike BEFORE you start tuning, or you run the chance of mis-diagnosing how the bike is feeling (I never start testing until I have at least 15-20 minutes of warmup time on the bike-I always ride stiff initially and sometimes do not get into a groove until then). Some guys can just jump on and pin the damn thing right from the truck. You know who you are, Wattsy……
      • Remember, this is a tuning session not the MXoN. Use you head and ride at a pace UNDER you max speed-there will be plenty of time to “fang it” once you have zeroed in on some good settings.
      • OK-ride and get a good feel for the bike with the clickers in the middle of their range. Now it’s time to really find out what “too soft” and “too hard” means.
      • Take your clickers and turn them all the way out, full soft. Go ride the bike, but take it easy-it will feel ALOT different. Then come back in and turn everything all the way stiff-go ride again, being careful as this will feel totally different again. For guys that have tuned a bit, these two steps might seem pretty basic, but you will be amazed at the difference in how the bike feels. This is especially helpful for guys who are just starting out.
      • Set everything back to baseline. FROM THIS POINT ON YOU WILL ONLY MAKE ONE ADJUSTMENT AT A TIME!!!!!!
      • So now you will want to determine your tuning range. The tuning range is what settings you will use to adjust for different conditions. For example, If you are an MX racer as well as an occasional singletrack rider you will want to use different settings for those conditions.
      • Fork compression is a good place to start. Ride your test section at baseline, then go about 3 clicks softer. The question to ask yourself after each adjustment is: Does it feel BETTER, WORSE, or THE SAME????
      • There are no right and wrong answers, only what you feel. So let's assume that the 3 clicks softer felt better-go 3 more clicks softer each time until it does not feel as good. You have just found the soft end of your fork compression tuning range. Now return to baseline and do the same thing, only this time go stiffer. After you have found the best compression setting, work on rebound. Remember, one adjustment at a time ONLY or you can become confused!!! Do the same testing with your shock. Once you have both comp and rebound individually adjusted, you can fine tune them to work together-just make one adjustment at a time!
      • As a final test, when you have what you would consider your best setup, write it down, then go back and compare that to your initial baseline, riding both setups back to back. Might surprise you…….
      I could go into some advanced tuning topics about the interrelation of compression/rebound, high and low speed comp, tuning for extremes, etc. but we will save that for another newsletter. Take your time, tune by how your bike feels to you and have fun. You will be surprised by how much better you will ride with well adjusted suspension.
      You can learn more at www.stillwellperformance.com
      KEEP IT PINNED!!!!
      Alan Stillwell
    • By Jo_nathan
      Selling the showa A kit off of my yz250. It comes with a set of like new x trig adjustable triple clamps. Have 4 rides on rebuild and overall in great shape. Few dings, no dents or leaks. Setup for a 165lb a rider. Work absolutely awesome! I got hurt and cant ride for a year so I'm selling off some of my parts.
    • By Kim Franz
      lookin to upgrade my suspension on my 06 cr250, curious whats possible with some work.
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
    • By lro
      I need a pair of Fork Boots for my Yamaha XT350, and Yamaha wants $44.50 EACH. Any goot aftermarket boots available?
