Pipe Guard for 04 CRF 450
I saw a CRF 450 with the pipe guard painted Honda Red the other day, does anyone know if that painted pipe guard can be purchased or was it painted by the Owner of the CRF? If it was painted by the Owner, what type of paint was used? Let me tell ya, that pipe guard looked COOL.
I'd like to find one that wraps around the front of the pipe more. My boot sometimes gets caught on the stock guard.
SWEED32 has his painted red, I forget what type of paint he uses. Send him a PM and I'm sure he will tell you. I do remember him mentioning that he has to repaint it from time to time due to it getting scratched.
This company makes rap around pipe guards. E-Line
thanks... just ordered one. Very nice people on the phone. I'll post thoughts after I get it.
Here is what I would recommend if you were planning on painting the stock pipe guard.
Sand blast existing coating off.
Primer with Zinc Chromate.
Paint.
Zinc Chromate was developed by the military. It is camouflage green in color and can be purchased at personal aircraft supply houses. Zinc Chromate is the best product I have seen for maintaining paint to super hot material including Aluminum. I first started using it when overhauling Rolls Royce engines for P51 Mustangs and have used it on several engines (and types of metal) since with very good success.
Now with all that said, if I was going to go through the trouble, I would probably anodize it instead of painting.
Anyone know of maybe an aluminum one like the eline? I wouldn't mind a guard going around the head pipe in the front either but you can almost buy a new one for $90.
Did it look like this ?
Wait till ya see it on your bike it looks sweet! Im getting one income tax time! :)
  • Similar Content
    • By jakebarritt
      I have a 2005 CRF450R with a Trail Tech fan kit installed. I need a little bit larger tank and would like to know if anyone has an aftermarket tank that fits with the fan kit.
      I dont need a monster 4 gallon, just maybe a 2.4 or 2.7 from IMS would do fine.  I talked with both the tank vendor and Trail Tech and neither could give me any answers.
      Thanks guys.
      Jake
      Minden, NV
    • By smythe
      Complete 2009 CRF 450r cylinder head with valvetrain.
    • By NickC18
      So I emailed Factory Connection today to see what spring rate I need for the rear as I’m about 6’2” 220 lbs without gear. I also asked for a baseline front fork PSI to start at. This is what I received:
      Nicholas,
      The spring series we made for your bike is limited when it comes to larger/stiffer rates.
      The spring rate you need is 5.9/6.0 range. We don’t sell that over the counter as it requires special installation process.  So we can’t sell the spring “over the counter”.  It would have to be installed at our shop.
      Fork PSI I would recommend:
      Inner 160 psi
      Outer 11 psi
      Balance 160 psi
      Are they blowing smoke up my ass? What kind of ‘special installation’ could a spring take? I’ve changed and removed them before but not on a 16’ CRF before.
      Also, aren’t those psi settings for the Kawasaki KYB? I don’t think the psf2 have inner/outer/balance do they? Maybe he was having a bad day...or maybe I’m an idiot. FC’s website list there spring as ALS-0059. Can I not just order this spring and install it to set my sag correctly? Help?
    • By johnsbikerepairs
      hi, i have a crf450R 2009, having difficulty setting the idle knob to factory setting.  Having problems interpreting manual Japaneses interpretation.  Can anyone out there assist with the correct factory setting and how i can manually do the setting ie how many clicks out or in etc...   would appreciate any assistance
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
