What is likely cause of misfiring on new bike ?
HELP!
I've got a new KLX300, just past the breakin period and it started misfiring under acceleration. Nothing really seemed to preceed the problem, no stalls, drops, etc. The gas in the tank is on the low side - I originally thought it was running out and switched to reserve but the problem still persisted. I'm going to fill the tank & try again but I have to trailer the bike to the riding place an hour away and want to find some solutions before I go. Is this most likely a fuel problem ? Breakin prolem ? Emissions ? Spark ? I'm unfamiliar with diagnosing engine running conditions...... Thanks for any input !
-JB
bad jetting.
JB,
Your KLX is jetted way lean to meet California's standards. Go to the KLX group and search around for just the same problem and you should be able to find your solution. If that does not do it, go to the jetting group.
The popping you describe happens under deceleration and your RPM's are up there right? It happened on my bike till I got the jetting squared away. :)
Jeff
OOPS!! I just re-read your post and you said it happens under acceleration, sorry. :D Check with the groups I mentioned for your cure.
It seems like the answers are leaning towards jetting - the bike ran fine for the first couple hours - why would it suddenly change if jetting is to blame ?
Good question-to me if it's jetting then the plug should be a good indicator.Different temps will change the mix.Check the plug for color.You might drain the fuel bowl and check for any debris or water.Is your air filter clean?
Is this is a new bike and under warranty. If it is take it back to a dealer. This is not your problem it is theirs.
Russ
If its that new, take it back to the dealer. If he won;t touch it you have some options:
1) Install a dynojet kit- works real well. Also, the CA models cover the air screw under the carb with epoxy. You can break it out and adjust it for deacceleration popping.
2) Check the valve clearances to make sure they are in spec.
3) My friend had a KLX that drove him nuts. He traded all kinds of parts, carbs, black boxes. Someone finally told him to check the brass screw/nut in the spark plug cap to make sure it was tight. That was it. It is a retainer for the resistor placed in the cap, and it was loose causing a sporadic misfire.
Look at the sparkplug first....It can tell you alot if you know what to look for.......Black and shiney center electroid...means its getting oiled from somewhere Aircleaner oil?
Black and sooty, too rich. Choke is on or you ran it too long on the choke and
loaded the plug up (fouled)
White with little specks of metal...
very lean ...air leak at maifold?
Try a new plug before you do anything else....then get worried..Probably a plug with one of these problems...
Plug cap being loose like Burnrider said
that makes sense also...Good luck.
BC :)
  • Similar Content
    • By Bryan Bosch
      Rockstar Energy Husqvarna Factory Racing Star battles Through All-New Format Hell’s Gate to Finish Second
      February 11, 2018 – (Motor Sports Newswire) – Rockstar Energy Husqvarna Factory Racing’s Graham Jarvis has earned a strong second place at the 2018 Hell’s Gate extreme enduro. With an all-new format for this year, concluding in a 20-minute sprint race, the event posed a fresh challenge for the five-time winner.
      For the first time ever, the event kicked off with a Prologue race on the Friday night. Designed to set the starting order for Saturday’s race, the Prologue was an endurocross style event held close to the hosting Il Ciocco Hotel. Although it provided a great spectacle for the fans, the race results were eventually scrapped due to issues with the course.
      Saturday’s heat race went well for Jarvis. An expert at managing his pace, the Brit did exactly what he had to do over the five-laps, finishing fourth aboard his Husqvarna FE 250 in the cold conditions of the Tuscan hills. The position gave him a good start for the night race, which saw riders set off at 3.30pm for a tough three-hour multi-lap event.
      At the conclusion of the night race, the top-10 riders were given a 15-minute break before contesting the new 20-minute endurocross in the arena area of the venue. In freezing conditions, the riders fought bar-to-bar in front of the record-crowd of spectators to decide the overall winner. With the final results calculated on the sum of the previous legs, Jarvis was announced as runner-up, just a few minutes behind eventual winner Mario Roman.
      Graham Jarvis: “I really enjoyed the racing today, I always do here at Hell’s Gate. It’s been a tough couple of days and I’m still getting used to riding the 4-stroke, but the bike has been absolutely faultless over the entire weekend. It has been pretty close between the top-four all day and it’s all come down to the final 20-minute race off. It would have been nice to take my sixth win at the event, but I’m happy with second.”
      Results – Hells Gate 2018
      1. Mario Roman (Sherco) 3:06:03
      2. Graham Jarvis (Husqvarna) 3:08:57
      3. Travis Teasdale (Beta) 3:12:45
      4. Diego Nicoletti (Husqvarna) 3:32:14
      5. Sonny Goggia (KTM) 3:39:26
      6. Michele Bosi (Beta) 3:46:15
      Husqvarna Motorcycles North America, Inc.
      Husqvarna has continued to expand its professional race team to compete in AMA Supercross, AMA Pro Motocross, AMA National Enduro, GNCC, AMA EnduroCross, and AMA National Hare & Hound championships. Husqvarna team riders are competing aboard Husqvarna FC 450, FC 350, FC 250, FE 350, TC 250 and TE 300 models.
      Rockstar Energy Drink
      Rockstar Energy Drink is designed for those who lead active lifestyles – from Athletes to Rockstars. Available in over 20 flavors at convenience and grocery outlets in over 30 countries, Rockstar supports the Rockstar lifestyle across the globe through Action Sports, Motor Sports, and Live Music. For more information visit: www.RockstarEnergy.com
      Source: Husqvarna Motorcycles GmbH
    • By deanmellor
      My top end went on m 98 cr 125, the needle bearing clip came out and broke apart and shrapnel got everywhere and blew it up. I cleaned out the top end and washed out the crank with the bike upside down. the bike starts up great and seems to run fine but im getting a weird di-di-di-di-di-di-di noise coming from the motor. i tried adjust the power valve and tightening everything but the noise is still there. Here is a link to a video where you can hear the sound. It gets louder as rpm's get higher and at really low rpm barely idling it goes away. I am pretty new to bikes and 2 strokes so any help would be appreciated.
      https://youtu.be/msfU8WCXg8E
    • By RidingWithStyle
      In need of Cycra Handguards (probends) for my bike. Need 1 1/8 clamp size for renthal twinwalls. Message me if you have any for sale at a good price!
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
    • By Chumbag
      I want to get a cheaper used FMF exhaust for my bike. The one on eBay I was looking at had some dents in it. Do dents in the muffler have a big impact on the performance? Also the pipe looks to be turned the wrong way does that rotate? I don't want to buy this if the pipe will not rotate because I think it looks like its turned the wrong way and wouldn't fit.
