Aftermarket Plastic?
Just wondering what is the best aftermarket plastic? I have a yellow '01 E and need two new rad shrouds, but want them to match the stock yellow tank as close as possable. Thanks.
acerbis and ufo are both good.
first thing get a honda :):D :D
Why would he want to downgrade? :D
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
