Looking for torque specs for oil cooler connects
Howdy.
I've added an XR400-type oil cooler to my XR300 (formerly an XR250). Understandably, my OEM XR250 shop manual doesn't list a torque spec for the (flange?) nuts that connect the oil llines to the oil cooler. Could one of you XR400 types with a manual please tell me the torque spec (assuming your XR400 OEM manual lists such a spec).
Thanks.
Dale
And thanks for the :)!!!
My XR400 manual says 14 ft.lb.
  • Similar Content
    • By libsead
      Guy's,  I have an 1997 Honda XR400R and I need to do the front forks.  I'm a big guy 6'4" 375lbs.  So far I haven't been able to find a setup for a big guy. Any suggestions besides losing a lot of weight. :-)
    • By Scat Adams
      OEM Rear fender from an XR400. Fender includes Baja Design tail light as well.
      $20 plus shipping, located in San Diego.
    • By Alex John Blanch
      Went riding on Christmas Eve  everything was working fine went through some mud and slipped dropped my bike tried to kick start it and the kick start went limp pushed it back up got compression again  kicked it over a bunch of times started to run again  rode it for the rest of the ride with no problems then on the way back on the road I gave it fill throttle  and it died hasn't started  since and now has little compression. Replaced the spark plug and changed the oil and filter and adjusted the valves but still very little Compression and won't start.
      Any ideas??  Would greatly appreciate
    • By Ricky Bobby 21074
      I have a 1986 xr250r, I'm interested in converting the rear drum brake wheel assembly to a rear disc brake system. Has anyone done this, and can you tell me what application parts will get the job done. thanks
