45 Sprocket
I'm looking to buy an 44-45 teeth sprocket but is looks like I can get only 47 teeths and up (At least thats what they got in TT store :)) Any idias where to get it?
44 is stock 400S
I have a 46 rear on mine bought locally, wanted a 47 but they could only get the 46 in the time frame i needed.
Sprocket Specialist i think it came from.
I have a selection of fronts to run with it 13,14 and 15T
I have a 45-tooth that I got from Ironman. Great lightweight steel sprocket with a one year guarantee. They are a bit spendy though.
  • Similar Content
    • By Caycee Justus
      I had a gsx-s750 and got rid of it and picked up a 2015 drz400sm this week. It's used and the last guy put knobbies on it. I'm switching back to Michelin power 2ct. stock tire size is 140/70. The current tires are 150/70. I was looking at running 160/60. Anyone know if this would be a problem? I'm just getting into the supermoto life so any other general suggestions would be great. Thanks!
    • By Supermotofool
      I totaled my DRZ400S last year, did a good bit of work to it and finally got it running.. I want to turn this into my full stunt bike.
      I have read before about people buying a 2nd stock rear caliper & bracket - then cutting and welding it to the existing bracket, then just running a handbrake master, and a hose to the 2nd caliper.
      Has anyone done this before? Defiantly seems to be the cheapest route to go (staying away from the junction valve / 1 master cyl. & 1 caliper setup.)
      Looking for opinions, pros/cons, and info if anyone has gone this route.. If it seems too much of a risk or hassle I guess im gonna have to spend the $500/$600 to get a legitimate setup
      any and all comments are appreciated - except trolls.. you better be funny as hell if your gonna troll.
      Thank you all!
       - Brad
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
