Antigravity Batteries Product Giveaways - LAST NIGHT TO ENTER! Read more... ×
Re-greasing the rear linkage on an 04 YZ 450.
I know I probably should have done this before now, but I'm wanting to re-grease the rear linkage on my bike. I've heard talk about some sort of plastic inserts that you have to cut out. Has anyone been through this yet? Any suggestions? Why would Yamaha put in something that has to be cut out to service the bike? Or was my info totally off track? Thanks
First of all dont be surprised if you go to open your linkage and its still plenty greased. I greased mine after a year of 3 days a week riding on my 03 and still had plenty. As for the plastic I dont know what your talking about. I will say watch out for the needle bearings as they like to stick to your gloves or fingers.
Are you talking about the plastic plugs in the swingarm? You shouldn't have to cut them out, they are only pushed in there. A good regreasing is good after buying a new bike, I used to assemble bikes out of the crate and some where very dry.
Once you regrease with a good moly grease it should last a while, unless you are in a wet climate. Also, in reference to the above: Unless Yamaha changed the bearing type from 02 to 03, your needle bearings should be within a fiber cage and should not come out. I replaced one of mine because the fiber cage had degraded and the needles were loose.
This thin "fiber material" is actually a type of solid lubricant that Yamaha uses on these bearings. You can either remove it and regrease, which would be a major pain, or just slap new grease right over it.
You are refering to the solid lubricant (yellow material) surrounding the needle bearings in the linkage.
I removed this material and took each needle out, packed the bearing with grease, and reinstalled the needles. This, in my opinion, is the best way to do it. It takes a little longer and you have to be more carful to not loose the needles and put them back in corectly making sure that you put the same number in as you have taken out. It is best to do one at a time. This is a huge mess, but it will be well greased when you are done. I have done my '04 twice and it is not that big of a deal.
Wow! Thanks guys. The fiber cage is what my friend was attempting to explain. He removed the cage also and replaced it with grease. I'll read the link above and decide what to do after that. Thanks for the help.
  • Similar Content
    • By BDTRENT
      Selling an FMF Power Core 4 exhaust system off my 450FX. Exhaust has 80 hours and is 100% functional. This will also fit the 14-15 YZ450F and 16-18 Wr450F. If needed I can also include new muffler packing although it does not need it.
    • By Woody Oakson
      I have a 2008 YZ450F with a stock header pipe and Pro Circuit T-4 Slip-On Exhaust. I'm 99% sure the slip on is shot because its loud as hell and when I take it off and shake it it rattles. I would repack it but the screws are all stripped ect.
      Anyways I've gone over the carb multiple times and I've got it running pretty well. The only issue I have with the bike is that it sputters and pops around 1/2 throttle when I hold it there. When I give it full throttle from any RPM it runs great or when I give it about 3/4 throttle it spins up like a top to redline.
      Initially the popping and sputtering was way worse I made the situation better by moving the pilot jet up in a few sizes from a 45 (stock) to a 62. The issue has gotten way better since then but I'm not super sure what to do from here. Should I keep moving my pilot jet up in size because that's a pretty large jump right? I tried changing my needle clip position but that didn't help much if anything it just made starting it worse and little to no impact on the ride.
      Any input on this would be helpful. I don't want to buy other slip on. Also as for the rest of the carb I'm very sure everything else in it is what it needs to be at. I've replaced all the gaskets and O-rings cleaned all the jets, valve holes ect. fixed the accelerator pump timing. I just thinks its strange that my pilot jet size is going so far from the stock 45, but all symptoms point to the bike running lean.
    • By Haydenbaha
      Hi I was wondering if y’all have been using a 450 on your YZ250F?
    • By RockerYZWR
      Excel Takasago 17x3 front and 17x5 rear supermoto wheels with Metzler M3 tires in very lightly used condition. Less than 200 miles total on the setup. Warp 9 spokes. Rear has a Talon hub with 45T Sunstar steel sprocket and OEM rear disc, and front has a polished OEM Yamaha WR450F hub (for the stock speedometer), with a Motomaster 320mm disc. Included is a DID gold o-ring chain, 14T front sprocket, and front brake caliper adapter for a truly turn key setup. Everything is in excellent condition, not a single scratch on these wheels. Came off my '11 WR450F, but will fit many different Yamahas with 20mm front and 22mm rear axles. Asking $1400 plus shipping.
      **Will be driving up near Atlanta, then to northern Louisiana, OKC, and down through Dallas and Houston, TX soon -- can meet or deliver if in the area (Aug 31-Sep 9)**
    • By YZ426fNC
      Hi I’m new on the forum and I was wondering if a 2001 Yamaha YZ426f clutch is interchangeable with a 2002 Yamaha YZ426f clutch thanks , Coleman
