What parts for a valve job?
It is time to replace my valves and I need to know which parts to get. The valves themselves are obvious, but is there anything else I need to replace, resurface, etc. when changing them out?
I am going to order a service manual when I order the parts, that's why I need to know ahead of time so I can order everything at one time.
Thanks
Are you going with stock?
I just picked up my SS kit which includes the stainless valves, retainers, springs, etc...
I know that springs are not an option but required when going with steel.
I have a connection with Honda so I will be sticking with stock stuff.
How much was the SS kit?
The spring kit was like 220 which had all the little stuff in it. The valves were 34 each. I think this is list or close to it. If you pull the racer discount out of that it came to 233 plus tax.
Does this part list sound right?
- 2 Intake valves
- 2 exhaust valves
- 2 Intake valve retainers
- 2 exhaust valve retainers
- Intake cotter valve
- Exhaust valve
- 2 intake springs
- 2 exhaust spings
- Intake valve stem seal
- Exhaust valve stem seal
Do I need to replace the valve spring seats?
I got these parts from the Service Honda web site. I don't really know if I need some or all the above parts.
Thanks
Dont forget to check your guides per the manual and blue check the valve face to seat contact areas with machinist blueing. One of my exhaust guides was borderline in spec and I had exhaust seat pitting.
Where can I find the blueing stuff and if it shows a poor seal, what then?
You can just use a black marker if you don't have any dykem blue.
Automotive parts shops. You are looking for the surface contact area being too high or low. I did not have this problem but it is good to check. Mine had pitting of the exhaust seats which would require cleaning up with a seat cutter. I ended up replacing the head because of the guide issue. The head was at Eric Gorrs and I was told replacement was the way to go for cost reasons. You may not have these issues but follow the manual it covers all of the top end checks in great detail.
  • Similar Content
    • By GarrettSG
      I need recommendations on Honda dealers with good Mechanics in Western Washington. I am in Puyallup but will drive for peace of mind. I have never had a dealer do major work on any of my dirt bikes. But long story short I am on a 15 CRF450R and it needs the 5th gear recall done. Any and all info is much appreciated!
    • By jakebarritt
      I have a 2005 CRF450R with a Trail Tech fan kit installed. I need a little bit larger tank and would like to know if anyone has an aftermarket tank that fits with the fan kit.
      I dont need a monster 4 gallon, just maybe a 2.4 or 2.7 from IMS would do fine.  I talked with both the tank vendor and Trail Tech and neither could give me any answers.
      Thanks guys.
      Jake
      Minden, NV
    • By NickC18
      So I emailed Factory Connection today to see what spring rate I need for the rear as I’m about 6’2” 220 lbs without gear. I also asked for a baseline front fork PSI to start at. This is what I received:
      Nicholas,
      The spring series we made for your bike is limited when it comes to larger/stiffer rates.
      The spring rate you need is 5.9/6.0 range. We don’t sell that over the counter as it requires special installation process.  So we can’t sell the spring “over the counter”.  It would have to be installed at our shop.
      Fork PSI I would recommend:
      Inner 160 psi
      Outer 11 psi
      Balance 160 psi
      Are they blowing smoke up my ass? What kind of ‘special installation’ could a spring take? I’ve changed and removed them before but not on a 16’ CRF before.
      Also, aren’t those psi settings for the Kawasaki KYB? I don’t think the psf2 have inner/outer/balance do they? Maybe he was having a bad day...or maybe I’m an idiot. FC’s website list there spring as ALS-0059. Can I not just order this spring and install it to set my sag correctly? Help?
    • By johnsbikerepairs
      hi, i have a crf450R 2009, having difficulty setting the idle knob to factory setting.  Having problems interpreting manual Japaneses interpretation.  Can anyone out there assist with the correct factory setting and how i can manually do the setting ie how many clicks out or in etc...   would appreciate any assistance
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
