if I set my rear sag...
Whats the factory Sag for a DRZ400s.
Im unable to find this in the Manual or online.
sorry, what I was trying to say is that my suspension has been untouched, it's at factory settings.
In my experience,when they come from the factory,they are nowhere near what they should be.
I found the folowing on www.racespec.co.uk
Setting Shock Spring Sag
Hopefully you have the correct spring for your weight. To determine this factor we must set the sag on the shock. To have the sag set correctly is as important as having the correct spring. So please take time to carry out this operation correctly.
(A)initial measurement
Put your bike on a stand with the back wheel off the ground and measure from a point close to the rear wheel axle to a point on the rear fender slightly forward of the vertical.
Measurement A ... (e.g.) 610mm
(:) Race Sag
Take the bike off the stand and put on level ground. Sit on the bike in a central position with all your kit on with one foot on a footrest and the other on the floor just for balance not weight bearing. You will need someone to take the measurement from the same two points.
Measurement B ... (e.g.) 510mm
610 - 510 = 100, (Race Sag : 100mm)
© Static Sag
The static sag is measured when the rider is off the bike and it is standing on its own free weight. You measure the same two points again, and then subtract C from A this will give you the static sag.
Measurement C ... (e.g.) 585mm
610 - 585 = 25, (Static Sag : 25mm)
Static Sag
Static sag should be set between . Midway between these measurements is a good starting point
125 - 500cc 15 - 30mm
60 - 100cc 15-25mm
Race Sag
Race sag should be set at between 25 - 30% of the bikes' full suspension travel.
125 - 500cc 90 - 100mm
80 - 100cc 80 - 90mm
60cc 50 - 60mm
yeahh.... My Static Sag is off. Ill have to measure it when I get home. Im 165#.
All the factory suspension settings were out of wack when I got the bike. Would doubt is one more is.
Sag is not something that can be set by the factory. It is dependent on the weight of the rider. Spec calls for somewhere between 3.5 and 3.75 inches. Many have up to 4 inches. The factory setup wil probably be way off. This one simple adjustment made my bike handle a lot better. I was amazed at the difference it made in my bike. :)
