DRZ400 Parts purchasing screw up clutch cover.
Hi I ordered a bunch of parts the other day for the DRZ400e
and Clutch cover gaskets was one of the items I ordered 2 of. I thought, I miss read the microfiche and ended up with 2 clutch covers. To save face and my Dealer any inconvenience and restocking fees I thought I would offer these items to the TT guys incase some one may need one at my cost of 90.00 retail these are 150.00. Let meknow if there is any interest. My best regards, jesse@rvi.net :) Jesse
Nice offer Jesse!
Any of you with those cracked cases, you might wanna jump on this. Many here have dealt with Jesse and he's for-sure good people. :)
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
