"raising" the footpegs on the 400S
Footpegs a bit too low. What are some good ways to raise the footpegs a bit? I remember seeing some weld on tops. Someone must have solved this. Thanks
Why do you feel they are too low?
Raising the footpegs while leaving the seat the same, does have implications. Be sure you know what and why you are doing this.
-Vince
They are low c/p to other bikes (KTM, WR, VOR). You notice it in ruts at speed, when the Tech8's come into their own :) Ride the other bikes through the same ruts and your feet don't come close to clipping the sides.
However yes it makes it a lot harder to go from the sitting -> standing position, and also isn't so good if you have dicky knees. Also, what about the gear and brake levers? It could be a hassle that's not worthwhile.... just be more careful of medium-deep ruts :D
The issue is hitting rocks with your foot because the footpegs are too low. I am prepared to raise the seat, but I hadn't considered the shift, brake levers.
  • Similar Content
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
    • By Surfman1
      Hello all, first time poster. Just bought this bike a few days ago it’s an 08 drz 400sm and am starting to notice it has a strange backfire at idle. I understand a little bit at decel might be normal, but at idle too?  It appears to have been jetted already, judging by the fact it has a jd jetting sticker on the bike itself. I know that it’s not an exact indicator it has but it could be. Has an FMF exhaust, it looks like a full system rather then a slip on but not entirely sure. A buddy recommended I mess with the air and fuel screw, haven’t done that yet. Just wanted to see if there was any other tips I should try.
