Chain Tensioner.... again / service intervals
Yeah I know, more CCT questions....
Any thoughts on how often you might adjust the Mech CCT once installed? I realize this could vary wildly from bike to bike, etc. but maybe a rule of thumb?
The Hyabusa tech didn't really have any comment other than to listen for noise. I hate to leave it alone until I hear it, but don't want to goof with it more than necessary.
Also, my bike only has 650 miles on it. Any issues with chain stretch
as the bike continues to find its point of equilibrium / break-in ??
Actually the tech / order guy on the phone cracked that 15-20 of us call him a day....
i have not adjusted mine since i installed it a year ago.ive installed them in many sport bikes and they never touch of the parts guys at the shop has had his in his busa for 10k miles.never needed adjustment.after the chain stretches initially it wont move much.
its done its stretching already.
still waiting for my royalties. :)
Outstanding !! Thanks !!
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
