Best way to install new graphics?
Well today my GYTR tank and rad fin graphics came in. These are pretty expensive and pretty big! What is the best way to install new graphics with out messing them up? I have heard spraying water on the plastic and then installing them, or using soapy water. However I don't want to make it so they are not sticky and fall off.
I use to use Windex. Just soak both the plastic and the decal and use a credit card to rub the bubbles out and to line them up. But what sucks is you spend lots of time putting them on, getting the bubbles out, making sure they line up, and your first ride out you dump it and they are sratched. Three weeks later the gas tank decals start to turn yellow and get lots of bubbles. But after the first few sets I put on, I started to just throw them on, and not spend much time on them because I knew I would be doing them again next month :).
This works real well. Clean the surface real well. Get a small spray bottle that is clean in the inside put one drop of dish soap inside add water. Shake up real well spray a mist on plastic then peel backing off graphic and spray that as well with a fine mist apply graphic and work into place. Then use a towel and rub out all the excess water from underneath as it starts to dry rub harder and just keep rubbing until completely dry works very well.
just use a bit of heat and start from one corner. i also covered them all with clear scuff stuff. as long as you prepare the surface properly they should stay on for a good while
Heres mine i just finished today
Nice job :)
Too bad it's a KX :D
I use nothing but windex, it works awsome. Try it. :)
Windex, a small soft plastic squeegee, a heat gun or hair drier, and a pin to poke the remaining bubbles. Be sure and clean the plastic where the graphics will go with something like alcohol and get all oils off it. It also is nice if the plastic and graphics are warm when you’re doing this.
Craig :)
So the stickers have no problems sticking or setting up when spray on the Windex? I also am guessing it will allow you to pick them up and put them down a few times?
Windex will evaporate as it dries.
I also have tried warm soapy water. about 1 - 2 drops of dawn in warm water enough to cover the plastic. This gets the graphics completly plyable.
It takes a while to squeegee things out but works well.
The best way to do it is to follow the manufacter's instructions. They all use different glues. Ask them what they recomend.
I have found that the best way to keep your graphics looking nice is to keep them in the plastic that you bought them in.
In other words dont install them.
ALL graphics installed on a yamaha will turn to crap in a time. It is because gas vapors leach thru the tank and attack the graphics. The kawasakis and Hondas have shrouds that cover the tank. There graphics stay way nicer.
My new wr250 that I am getting is going to have the stock graphics on it till they fall off then it is getting nothing else. I am tired of throwing money at stickers. They dont make the bike run any better or go any faster.
Shrouds HUH? Never have seen them before.
The radiator shrouds?? The ones that attatch to the radiators on your bike. What the heck do you call them, plastic air scoop thingys?
One thing about using soap is that it will leave a small amount of residue between the adhesive and plastic this may make the adhesive not hold as well.
The Windex will also evaporate quicker and squeegee out easier. It gives you enough time to slide the graphics into place.
my 2 cents
Craig :)
Well I will try it tonight! Windex it is!!! I see what your saying, Honda's go up further and they don't have much stickers on the tank.
Windex is the only way to go...
I also suggest once you get them installed to run a bead of clear finger nail polish around the edges. Really helps to keep the edges from starting to peel.
to prevent bubbles take a razor blade and recut the perforations.. the graphics ive put on were not punched thru all the way and they wanted to bubble. reperfed them and ive got 2 yrs on them now no bubbles and not pealing. also use contact or brake cleaner to make sure plastic is clean.ive done 2 sets of graphics this way and both are doing well
Ive done the same thing on my last few sets of graphics...seems to eliminate some of the yellowing also.
  • Similar Content
    • By Zack Ailing
      hey guys just picked up a new project bike. Its a 2008 Yz450f with a big bore kit and a stroker crank. The total cc of the engine is now 499. It runs on race gas and will be an absolute monster when shes ready to rip. I will continue to make more videos on the bike so stay tuned Link to the video:
    • By High On Octane
      2005 YZ450F, Athena Big Bore, Power Bomb, Q4.
      Ok.  Last fall after a decently hot day at the track, I noticed coolant leaking from the weep hole on my water pump after pulling into the pits.  Ordered an Athena re-seal kit, put it all back together and didn't really get a chance to ride it.  3 weeks ago, went out to the track, and after about 20 laps, it started leaking again.  Kept filling it with water to get thru the day, never ran anywhere close to dry or empty, jut a cup or 2 low.  Ordered a Hot Rods re-seal kit with bearing and also ordered a new w/p shaft.  Did it all again and got it back together, ran it, and as soon as it got to temp, it was leaking out of the weep hole again.
      So, what the heck am I missing?  I'm totally stumped on this one.  Is something wrong with my case cover?  Do I need to replace the w/p itself?  I'm feeling like I should've just ponied up for the Boysen in the first place, and now it's biting me in the butt.  Any help or suggestions is greatly appreciated.  Thanks!
    • By Awheeler25u
      Alright guys, my 04 YZ450f runs fine minus some slight backfires when decelerating (need to adjust fuel screw). The other day when I was done checking my valve clearances I changed the oil and filter and put the bike back on the stand, kicked it a few times without the ignition coil in to get some oil flowing got off and noticed a little drip spot on the ground, it was no bigger than a dime so I thought nothing of it. Started the bike with no issues took it for a quick 10-15 min ride, came back to the garage to find out my whole case was soaked with oil and it started pooling in the low spots on the clutch basket side. I cleaned all the oil off and took it out again for 5 mins to try and see where it was coming from, here are my three possible places but nothing directly leads me to believe it’s any of the three either.
      1. Decompression plug area
      2.  Valve cover gasket leak (not really sure because the amount of oil leaking Looks to be a large amount
      3. Oil tank (bad weld or cracked weld somewhere
      what are you guys thinking?
    • By bofar
      Hey guys. I could really use your help diagnosing an issue that came up riding today. Bike is a 2013 YZ450F. Well maintained and haven't had any issues until now. Both the oil and coolant are new and levels are to spec.
      After riding for about an hour in the sand dunes, I noticed a grinding going on on the right side of the bottom end (from what I could tell). When I looked to see what was going on my kickstarter was vibrating and grinding really loud. This was a different sound than if you engaged the kickstarter while running. It sounded less "clanky" and more "vibrating/grinding" if that makes sense. Grabbing the kickstarter and moving it didn't help the issue.
      When I noticed it, I shut the bike off and gave it a second. Being a few miles deep into the dunes, I had to get it out of there so I started it back up and it seemed fine- no grinding. I headed back to the car and after a few minutes, it came back so I shut it off again, started it back up and nothing. That process happened one or two more times before I made it back to the truck. Seemed to run fine otherwise.
      Once I got it back to the truck I started it up and tried to pay more attention to what was going on but it wasn't doing it. I did seem to have more of a metal on metal noise coming from the motor. I started and stopped the bike a few times and after the motor stopped there was a distinct metal clank/grinding noise that happened right after the motor shut of for maybe half a second. This doesn't happen every time.
      I tried doing some research and have seen things that make me think it could be the spring that connects to the kickstarter, or the kickstarter stopper plate- but really I have no idea.
      Seems strange that the issue is off and on.
      Thanks for the help!
    • By Goof331
      Does anyone know if there is any differences between the 2 radiators? Will the yz450fx radiator bolt on a yz450f? What I am wanting to do is wire up a fan to my 2016 yz450f. I know how I am going to do it I just don’t want to use a “universal” fan kit. What I would like to do is get a 450fx radiator and the direct bolt on Trail Tech fan for that radiator to have a good clean look.
