rear spring question
my bike has the factory rear spring and I weigh about 215. Should I go with a different spring for my weight? I need to lose a little weight anyway, so this might not be a bad goal to work towards, lose a little weight for the bike. What is the target body weight range for the rear spring?
You can get some good info on I just got a heavier fork and shock spring for my supermoto. They say the stock rear spring is set up for a 180 pound rider. :)
You're undersprung based on the technical knowledge available here. I have ordered the correct race tech fork springs and shock spring for my weight (205). I'm not going to do a revalve yet. I want to see what kind of difference the springs make.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
