MX Handguards
I am looking for some MX handguards that fit the 04. I bought the Acerbis MX light hand guards and the plastic mounting bracket doesn't go over the hot start and clutch properly. I also tried the Cycra MX guards and they don't acommodate the hot start as well. What fits the 04?
Just get the Dr.D hot start which moves it over to the front brake side. Then you can use a CR250 perch and run whatever handguards you want.
I have the Cycra stealth MX guards and really like them..easy on , easy off.
E-WA,
Those Cycras look good. Do they work fine with stock hotstart? Is it the same on the '04, I noticed you have an '03? It looks like the mounting system is much better than the Acerbis flag system.
I'll post a picture and show you the Hotstart side.
I've got the Cycra Stealth guards on my '04 and they fit okay. I also have Universal oversize bars on it. On the hotstart side the mount that sticks out goes between the clutch lever and the hotstart IMO to get it to fit the best. You also have to move the kill button to the right side of the perch. I looked all over for mx style handguards for this bike and they are the best i've found so far. My only fear is that they don't seem like they would flex much if you wad it hard and could break taking the hot start lever and/or perch with it. I may still try to find a better solution. :)
Thanks for the pics. Looks like it doesn't interfere too much with anything. Is the plastic pretty strong? I would guess it would be similar to the Acerbis flag, which is what I had before.
Their just roost guards...I like them for the ease of taking off and putting on. If you didn't like the shape, just bolt different brand to the mounts.
  • Similar Content
    • By GarrettSG
      I need recommendations on Honda dealers with good Mechanics in Western Washington. I am in Puyallup but will drive for peace of mind. I have never had a dealer do major work on any of my dirt bikes. But long story short I am on a 15 CRF450R and it needs the 5th gear recall done. Any and all info is much appreciated!
    • By jakebarritt
      I have a 2005 CRF450R with a Trail Tech fan kit installed. I need a little bit larger tank and would like to know if anyone has an aftermarket tank that fits with the fan kit.
      I dont need a monster 4 gallon, just maybe a 2.4 or 2.7 from IMS would do fine.  I talked with both the tank vendor and Trail Tech and neither could give me any answers.
      Thanks guys.
      Jake
      Minden, NV
    • By NickC18
      So I emailed Factory Connection today to see what spring rate I need for the rear as I’m about 6’2” 220 lbs without gear. I also asked for a baseline front fork PSI to start at. This is what I received:
      Nicholas,
      The spring series we made for your bike is limited when it comes to larger/stiffer rates.
      The spring rate you need is 5.9/6.0 range. We don’t sell that over the counter as it requires special installation process.  So we can’t sell the spring “over the counter”.  It would have to be installed at our shop.
      Fork PSI I would recommend:
      Inner 160 psi
      Outer 11 psi
      Balance 160 psi
      Are they blowing smoke up my ass? What kind of ‘special installation’ could a spring take? I’ve changed and removed them before but not on a 16’ CRF before.
      Also, aren’t those psi settings for the Kawasaki KYB? I don’t think the psf2 have inner/outer/balance do they? Maybe he was having a bad day...or maybe I’m an idiot. FC’s website list there spring as ALS-0059. Can I not just order this spring and install it to set my sag correctly? Help?
    • By johnsbikerepairs
      hi, i have a crf450R 2009, having difficulty setting the idle knob to factory setting.  Having problems interpreting manual Japaneses interpretation.  Can anyone out there assist with the correct factory setting and how i can manually do the setting ie how many clicks out or in etc...   would appreciate any assistance
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
