Garage gremlins
Do you have gremlins in your garage? I find that when I'm working on my bike, especially if time is short, I loose tools and parts. No matter how well I organize the stuff. I turn around to use a tool or get a part i.e. washers, bolts, circlips etc and their gone!! Darn gremlins must be stealing my stuff. Is it just me? I think its a conspiracy. I will be in the middle of a critical operation and my wife will call for something or the phone or door bell rings. When I return I have lost my place and my parts and tools are gone. Are they selling my stuff on E-bay? Does this happen to you?
I hate that too.....I usually find the stuff in very obvious places, like my hands :)
For sure it happens to me......changing the oil takes a hour to do. :D Just to find the drain bolt under my tool box. :) Can you say being mad for an hour...oh man I was. :D Wife and kids stayed out of the garage that hour too. :D :D
Ain't no gremlins, its just you getting old!!
Now you know how it feels :)
I think your right. I'm 45 and just found out that I need reading glasses!!! I think i'll paint my walker red.
It's the socks that do it. The 1 sock that goes missing when the laundry gets done... it sneaks out to the garage and when you're not looking, steals nuts, bolts, and small tools. Then, the next time you're doing a large tear-down/rebuild, it sticks extra nuts and bolts in the pile so you wonder where they go when you are all through. Damn socks! :)
Ok that's it...I'm putting a lock on my sock drawer. That will teach them!!
I just did an all out search for my feeler gauges (which I normally leave in a parts bin in the top of my tool box. I was convinced it wasn't there and scavenged the whole garage (finding other lost tools in the process LOL) Took one last look in the parts bin before heading of to Sears to buy a new set and there it is, right where it should be and right where I left it. :D The gremlins must be in my mind. Should I even be working on a dirt bike? :)
A while back I had changed four tires before a week end trip. I got to the last tire and could not find one of my tire irons I didn't leave the garage where could it be? I thought maybe some how it was inside the last tire I put on so I spun the tire and it stopped with the wheel lock down OK thats good. But I still couldn't find my tire iron. I gave up and went to buy a new one. Three weeks later I found it after 2 days riding and an 80 mile desert race it was sticking out my tire and the tire wasn't even flat. I am sure the gremlins put it there.
Feeler gauges? That happens to every other tool I use! They disappear and reappear all by themselves.
One thing I've learned. If a particular tool has seemed to completely leave this universe,look on the seat of the motorcycle you're working on .
  • Similar Content
    • By 33KTM350
      I just bought a Magura hydraulic clutch for my 2014 CRF450R.  Bought it thinking install would be easy, and I'm not sure that's the case now that I have the product in my hands.  I have searched the forums, YouTube, etc for install help specifically for my model year (2013 and 2014 are same really), and haven't found anything specific for the 2013-2014 model install at all.  Instructions from Magura are TERRIBLE, and are not specific at all to the Honda - generic instructions - so I'm debating if I want to return the product, cuz I don't want trouble or a big install job.  Question: for the 2013-2014 CRF450R install ONLY of a Magura Hymec hydraulic clutch - other model years are different and thus it won't be helpful for other model years - do you have any tips or feedback?  My concerns are below...
      1.  The 2014 model has a sleeve behind the clutch actuation arm that the Magura clutch slave cylinder fits into.  Stock, the sleeve holds one end of the cable, with a nut on the other end to keep the cable end tight in the sleeve.  The Magura slave cylinder, however, slides into the mounting sleeve  - but does NOT have a nut: the tension from the clutch actuation arm pulling on the metal Magura slave cyl tip end is apparently supposed to keep the Magura slave cylinder tight in the mounting sleeve.  Q: Will the Magura slave fit in to the mounting sleeve easily, stay tight, and is there any adjustment needed in order to keep the 4-6mm of freeplay that Magura recommends?  How easy is it to get the Magura slave fitted into the sleeve and the metal tip in place?  Is there enough freeplay between slave and tip end to mount in actuating arm AND the holding sleeve, so that the holding sleeve doesn't need to be unbolted?
      2. The stock clutch cable and OEM setup runs out of the mounting sleeve (see pics marked "metal starts", and then runs through a metal sleeve that routes the cable through the engine compartment - keeping the cable away from the hot parts of the engine case, so as not to melt the cable insulation (I believe).  That metal sleeve is about 6-8 inches in length.  The Magura clutch cable, on the other hand, exits the Magura slave cylinder at an angle - yet has no such metal routing.  I don't think the OEM metal routing sleeve will accept the Magura cable either, so a) the OEM metal routing sleeve would have to be removed first before installing the Magura - and then b) you have to hope that the Magura cable can be routed in such a way with zip ties holding the hydraulic line that line will not touch or be close to the hot metal engine casing as you route it through the engine.  Q: how easy was it to get the OEM clutch cable and metal routing sleeve out?  Easy as unscrewing the nut on the other end of the OEM cable, on the other side of the black rubber cable flange in my pics?
      3.  My stock clutch pull isn't bad.  I just like the feel of a hydro clutch.  Any feedback on how much better feeling and easier pull will be with the Magura?  What's your feedback on the difference?  FYI, I'm leaving my clutch plates and springs stock.
    • By Eric Blasiman
      We have a 2016 CRF450R with about 11 hours out. never ridden hard always check the oil and change when needed along with the air filter. Took care of the recall that was required as well. Well when riding the bike was stalled out. Went to try and kick start the bike again. the kick start lever just back up jamming my knee into the handle bars and some how ended up cracking the case right by where the kick start goes through the case. Has any one had this happen or heard of this happening? What is the cause?
    • By crfjunky1320
      Any advice on what should be replaced while I have the top end off for a valve replacement. Will do headgasket and springs of course, anything other parts you would recommend while I'm going at it?
      Thanks!
    • By Ron Whitfeld
      The dirtbike is on it's forth year right now on the same motor job. I have to jump start it. Is it worth me trading for a 2009 650 brute force with7000 miles? Need some expert advice. Thanks
    • By Lucas Hansen
      Just wondering what you guys do to remove black marks on your seat. My 08 crf450r has the red/black seat, and after each ride there are some black marks on the red from my riding pants. Not scuff marks, more like patches of black residue from my pants rubbing on the seat. I’ve tried the magic eraser which seemed to do the trick, but lately they seem like they aren’t coming off. Also tried scrubbing bubbles with a brush and no luck. Not too worried cuz I have an spare OEM seat, but I’d like to keep this one nice. Any ideas? Maybe I shouldn’t wear black pants?
