paging MD_DRZe
Check your private messages.
Thanks.
Mike
  • Similar Content
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
