Decomp plugs ready
All,
The aluminum blanking plugs for the manual decomp shaft hole are done and ready to be shipped. The price is $5 ea and includes shipping. PM me with your mailing address and quantity. I'm going to ship the plugs on the honor system until someone proves me wrong. Sorry, no Paypal, please send a money order, personal check or cashiers check.
Photos of plug and installation;
http://www.ofoto.com/BrowsePhotos.jsp?&collid=697578752103&page=1&sort_order=0
I might have to order a plug...The stock '03 rubber plug is just asking to blow out at just the wrong time...
That's why I'm getting one..... :)
Sent ya a PM. Does anyone know the part number of the rubber gromet that the plug fits into?? I took mine out when I plugged it.
All,
Links is not working :)
I am confused :) Do I haved to get a seal to use with this new plug?? I orderd one, but what else if anything do I need. The picture link does not work for me.
I am confused Do I haved to get a seal to use with this new plug?? I orderd one, but what else if anything do I need.
I asked the same question here was his answer
You'll need to purchase the pre-2003 lip seal (Yamaha part # 93102-12224) for around $3 to use with the aluminum plug. You'll have to remove the rubber/steel plug installed at the factory then insert the lip seal and plug. The main difference is that the aluminum plug is held in by the retention screw and can't come out. The factory plug is a friction fit and not all that good.
Correct me if I'm wrong but I'm thinking as long as you don't pull the old decompression lever seal out of the head, you can just slide the new decomp plug in, install the retainer bolt and call it a day.....
Tony,
You are correct, I designed the plug so that the decomp arm slides out and the aluminum plug slides in and uses the existing lip seal. As long as the lip seal is in good condition you're good to go.
The flange on the front of the plug was designed/sized to hold the seal in as well as protect the interface from pressure washers blowing water past the seal into the engine. Some of the guys are cutting off the decomp lever flush with the seal and in my opinion it might pass water if hit with the pressure washer.
If you have already plugged your engine or in the case of the 03-04's you'll need to remove the rubber plug, install the lip seal (# 93102-12224)and aluminum plug.
Hope this helps, by the way, there are only a few plugs of the original 50 left. I'm going to have the shop order more material and machine 50 more.
Fritz
http://www.ofoto.com/PhotoView.jsp?collid=697578752103&photoid=916198403103
Got mine today also. Looks great!!!! I love cool machined parts like this.
Got mine today! Very nice work :)
Watch for my check, it's headed your way...
The '04's almost ready!! GNCC Texas here we come!
Also, thanks for the advice to you, Wyatt. Hour-meter good to go, 6oz. Dr D flywheel and D-shape can on. Enjoy graphics on all blue plastic. This thing is looking bad!
If I can figure out how to get a photo posted, I can't wait to show the rest of you TT guys this bad boy.
Vibeguy,
Got mine today! Thanks for the quick service :) It's a great sano mod that I would recommend to anyone with a decomp cam.
Would you believe my local po-dink dealer had the oil seal part in stock :D
$4.03 is what im paying for the oil seal which is required for the plug installation. :)
Vibeguy-
Got mine on Monday. Great workmanship. Super shipping. Thanks..
  • Similar Content
    • By BDTRENT
      Selling an FMF Power Core 4 exhaust system off my 450FX. Exhaust has 80 hours and is 100% functional. This will also fit the 14-15 YZ450F and 16-18 Wr450F. If needed I can also include new muffler packing although it does not need it.
    • By Woody Oakson
      I have a 2008 YZ450F with a stock header pipe and Pro Circuit T-4 Slip-On Exhaust. I'm 99% sure the slip on is shot because its loud as hell and when I take it off and shake it it rattles. I would repack it but the screws are all stripped ect.
      Anyways I've gone over the carb multiple times and I've got it running pretty well. The only issue I have with the bike is that it sputters and pops around 1/2 throttle when I hold it there. When I give it full throttle from any RPM it runs great or when I give it about 3/4 throttle it spins up like a top to redline.
      Initially the popping and sputtering was way worse I made the situation better by moving the pilot jet up in a few sizes from a 45 (stock) to a 62. The issue has gotten way better since then but I'm not super sure what to do from here. Should I keep moving my pilot jet up in size because that's a pretty large jump right? I tried changing my needle clip position but that didn't help much if anything it just made starting it worse and little to no impact on the ride.
      Any input on this would be helpful. I don't want to buy other slip on. Also as for the rest of the carb I'm very sure everything else in it is what it needs to be at. I've replaced all the gaskets and O-rings cleaned all the jets, valve holes ect. fixed the accelerator pump timing. I just thinks its strange that my pilot jet size is going so far from the stock 45, but all symptoms point to the bike running lean.
    • By Haydenbaha
      Hi I was wondering if y’all have been using a 450 on your YZ250F?
    • By RockerYZWR
      Excel Takasago 17x3 front and 17x5 rear supermoto wheels with Metzler M3 tires in very lightly used condition. Less than 200 miles total on the setup. Warp 9 spokes. Rear has a Talon hub with 45T Sunstar steel sprocket and OEM rear disc, and front has a polished OEM Yamaha WR450F hub (for the stock speedometer), with a Motomaster 320mm disc. Included is a DID gold o-ring chain, 14T front sprocket, and front brake caliper adapter for a truly turn key setup. Everything is in excellent condition, not a single scratch on these wheels. Came off my '11 WR450F, but will fit many different Yamahas with 20mm front and 22mm rear axles. Asking $1400 plus shipping.
      **Will be driving up near Atlanta, then to northern Louisiana, OKC, and down through Dallas and Houston, TX soon -- can meet or deliver if in the area (Aug 31-Sep 9)**
    • By YZ426fNC
      Hi I’m new on the forum and I was wondering if a 2001 Yamaha YZ426f clutch is interchangeable with a 2002 Yamaha YZ426f clutch thanks , Coleman
