fork oil
I am going to be using 15wt belray fork oil and i would like to know how many ounces i should use? I would like to have alittle stiffer forks. If you dont use ounces how do i measure how much i put in to the forks...Should i use a measuring stick and stick it in there or what? :)
The manual says use 10wt fork oil but im using 15wt. It also says to use 156cm or 5.27 US oz. Will it make my forks stiffer if i use more? :)
