new 230 oil questions
brand new 230. what weight oil is used? how much? how long before break-in? what's the breakin procedure? when can i change to synth oil? i know this is probably in the manual but i don't have.
bill
No owners manual? :D It’s not hot is it? I see you have some other toys so I guess you’re legit. :D I just use the Honda GN4 10W-40 per the manual 1.1 quarts.
Break in:D…..hmmmmmm………. I don’t like the recommended break in. Hope I don’t get flamed for this but I did some research & this is what I do. Feel like I need a disclaimer. BTW Bike seems to run strong too.
1. Ride bike for 5 minute intervals. So, as not to overheat it while it is still tight (Don't ya love that smell the first minute you start it up? It's only once.). Get back on it when I can hold my hand on the fins. Yes, it is tedious.
2. Change oil after 3 five minute runs. Oil is also the tranny oil & there are lots of metal shavings in it. Breaking the tranny in too.
3. During each run (at least the first three) give a short full power blast. This is to increase the cylinder pressure spreading the top ring tight against the cylinder wall allowing it to seat nicely.
4. One gal of fuel(50+ miles) should get it broke in for continuous use. I'm just being cautious on this one.
5. Change the oil again.
The service manual says to change the oil every six hundred miles. That would be about six tanks of gas. I change more like every 2 tanks or three rides which ever comes first.
The owners manual says, “During the first 15 miles avoid full-throttle starts & rapid acceleration.” If you do this you can wear down the cutting edge of the top ring before it really seats well. :) Then it will never cut the seat properly unless you re-ring it. It’ll run ok but the power loss is about 5% per dyno testing. The guy that wrote the article builds & tests high performce auto engines for a living. If I find the link for it I’ll post it on TT, just not sure where.
Going directly against the owner’s manual. So, consider this the usual disclaimer for TT & myself. :D
I've asked the same question and got different opinions.Fundamental to all answeres was to vary the throttle and do not run it at sustained rpms.The site I was referred to sounds like the advice from Toast.Apparently the first 20 miles is critical for a good seat on the rings to cylinder wall.Short bursts of throttle and deceleration;much like a single track that's technical putting you in 2nd and 3rd gear.The other important tip was to let the bike warm up and don't rev it before you load it up.Along these lines you would want to stay away from synthetic for a couple of hundred miles.Again like mentioned the idea is to load up the rings to put pressure on the cylinder walls ie;acceleration and deceleration.I too went short times but they were 15 min.at a time and then cool off.
Thanks, Maco. Yep, I left left that out. :) Warm it up first.
Also, changing the oil like that may be over kill but there's lots of metal in those first oil changes & just makes me feel better to get it out of there. Especially, since the 230 has no filter.
Nice feature article from Motocross Action Magazine for this month. I can't really disagree with anything they say. This long but I think worth while for me to type.
This is not the start of a argument but take it for what it is worth. This comes from the motorcycle industry but NOT an oil company. They are not recommending specific brands of oil . Neither do I .
There is no need for descussion here. Use what you want. I just thought it was a nice article and wanted to share it. There is a UMPTEENTH line discussion going on elsewhere in the forum .
Cher'o,
DWIGHT RUDDER
Sumpology
Secret World of Four-Stroke Oil
There's more to it than car oil
The life blood of a four-stroke engine is motor oil. It breathes it, eats it and oozes it. Most four strokes, save the CRF450 and CRF250, use the same oil to lubricate the valves, cam, piston, crank, clutch, and transmission. This shared oil forces the motor oil to lubricate more than double the moving parts as the independent premix and gearbox of a two-stroke.
In an effort to reduce weight , maximaize power and trim the cases , your light-weight four-stroke motorcross engine uses just enough oil to get hte job done. On a racing machine , it's more important than ever to use the best racing oil made and to change it rutinely.
Q:
IS AUTOMOTIVE MOTOR OIL BAD FOR A MOTORCYCLE ?
A:
Not bad, but probably not the best. Why not ? It is designed in reverse order to a motorcycle oil. The priority hierarchy of automotive oil is :
( 1) Maximize fuel economy .
( 2) Reduce emissions.
( 3) Offer protection for the moving parts.
Today's automotive motor oils do not have the same degree of extreme pressure and anti-wear agents that they did just a decade ago.
Q:
WHEN WAS AUTOMOTIVE OIL AT ITS BEST ?
A:
Oil changed ten years ago when automakers were pressured to clean up the air. Since 1993, the entire automotive industry has worked to reduce exhaust emissions. Automotive motor oil must adhere to the performance categoies set by the American Petroleum Institute ( API ) .
These are called the API service categories. The API categories have been around for 50 years, but for the first 35, the categories were upgraded six times to meet the demand for higher engine performance.
The current API designation is SL. The API SL oils are designed to provide better high deperature deposit control and lower oil consumption. SL oils are missing important agents that improve extreme use lubrication. In their place are friction modifiers that improve fuel economy.
Q:
WILL AUTOMOTIVE MOTOR OIL HURT MY BIKE ?
A:
It could. If you're using and automotive motor oil in your racing four-stroke , you're not buying the best protection. An API SL oil is missing vital anti-wear components:
The most important being Zinc, Phosphorus, and Sulfur. These agents are harmful to the catalyst tha is used to diminish the level of pollutants in automobile exhaust.
Q:
WILL AUTOMOTIVE OIL HURT MY CLUTCH ?
A:
YES ! The friction modifiers in motor oil improve fuel economy by making it easier for the gears , bearings, pistons and rings to slip , slide and turn inside the engine. Unfortunately, these friction-minimizing agents also make it easier for the clutch in a motorcycle to slip. If you are using automotive motor oil in your bike , apart from CRF's, you are losing hook-up and acceleration, as well as reducing the life of the clutch.
Q:
WHY SHOULD I MEMORIZE THE ACRONYM " JASO" ?
A:
As soon as it became apparent the the American Government was mandating economy over protection, the Japanese Automotive Standard Organization ( JASO ) developed a standard specifically for performance four-stroke motocycles. JASO designates two different four-stroke oil classifications:
MA and MB.
The MB il is low friction and the MA is sans the friction enhancers ( ie. Honda synthetic silver and gold )
Q:
WHY ARE MOTORCYCLE -SPECIFIC OILS BETTER ?
A:
Motorcycle specific oils are pumped up with five times the anti-wear , anti-scuff and extreme pressure additives of regular motor oil. As an added plus, motorcycle oil does not include ( except for MB rated Honda Silver ), molybdenum disulfide and other friction modifiers that wreak havoc on clutch performance.
Maxima, a popular motorcycle oil supplier, starts with a API SG Service Category base oil, the last formulation that was't regulated as to the amount of Zincdialkyldithiophosphate ( zinc, phosphorus, and sulfur ) it could contain. Maxima then boosts protection through a proprietary mix of performance additives. The end result is a motorcycle oil that doesn't break down under extreme heat and is tough enough to cushion meshing gears.
Q:
WHICH FOUR-STROKE RACING OIL SHOULD I USE ?
A:
If the bottle of oil doesn't list that it is an API SG Service Category or JASO MA spec, it's not good enough for your motocross bike. Although a bottle of oil might say "motorcycle specific" or "safe in wet clutches," the best endorsement is the API SG or JASO MA designation. It's better to be safe than sorry.
There is a caveat that applies to CRF owners, however --whic we will clear up in a few paragraphs.
Q:
WHAT VISCOSITY SHOULD I USE ?
A:
The most popular viscosity is 10W40. It's thin enough not to bog down the crank and offers ultimate protection uder an extreme lad. Every owner's manual lists the recommended oils, brands and viscosities.
Q:
HOW IS A CRF LIKE A CAR ?
A:
The Honda CRF oil system separates the combustion side of the engine from the transmission. The CRF separates the engine sump to keep the metal shavings from the transmission from floating around in the same oil that is use to lubricate the piston , rings, and rod and crank bearings.
The upside of this design is that the CRF can use a slipperier JASO MB - spec oil in the top-end, while using a JASO MA-spec oil in the transmission.
Q:
WHAT ABOUT THE CRF TRANSMISSION ?
A:
Do not use automotive motor or gear oil in the CRF transmission. It the gear oil doesn't have the word "two-stroke gear oil ", safe to use in wet clutches, Or the API SG or JASO MA designation, don't use it.
Q:
IS IT BETTER TO SEPARATE THE ENGINE AND TRANSMISSION OIL ?
A:
Yes and no.
Honda uses separate oil for the CRF's top-end and transmission. This is not a new idea. BSA did it decades ago. Yamaha , Kawasaki, KTM, and Suzuki use the same oil in the top-end and tranny.
Which is better ?
Separate oil:
The benefit of separating the oil, like Honda does , is that the top-end is not contaminated by clutch debris or broken teeth. Additionally, hte heat of the combustion side doesn't thin out the transmission and clutch oil. The CRF can use an MA-series oil in the tranny and slippery MB-series oil in the top-end.
The downside is that the oil quantity in each chamber is reduced ( to approx. 650cc ),
increasing the need for more frequent oil changes. Any oil loss , no matter how small, becomes critical when you have a small pool to draw from.
Shared oil:
The benefits of using the same oil throughout the engine, like the RM-Z, KX-F, KTM, and YZ-F, are that the lare supply is less likely to reach critical levels, overall engine temperatures are reduced and oil changes aren't demanded as frequently. On the downside , shared oil engines must use an MA-series oil for the clutch ( which means that the top-end doesn't get the benefits fo the slippery MB friction modifiers ).
Q:
WET SUMP, DRY SUMP OR SEMI-DRY SUMP ?
A:
Don't get to confused by these terms.
by definition they are different, but in action they all work about the same.
A wet sump engine has a pool of oil in th ecrankcase. A dry sump engine doesn't store oil in the crankcase , but instead in a remote tank and oil lines. A semi-dry sump engine is , in reality , just a marketing term for a wet sump engine that tries to elevate the cranshaft out of the pool of oil .
The Yamaha YZ-F is a dry sump design. All other four-strokes use wet sumps, although they go to great lengths to avoid the negatives of an old-school oil pan under the engine. Suzuki and Kawasaki coined the semi-dry sump termenology, but the KX-F and RM-Z are at the very least semi-wet sump engines.
Q:
CAN OIL MAKE MORE HORSEPOWER ?
A:
YES.
Special blends of low viscosity ESTER SYNTHETICS cna protect like a 30W under extreme use, but let the crank spin like it has a 0W. Zero weight is the same viscosity as water.
But, the real secret to getting horsepower out of four-stroke oil is to use less of it.
Most modern four-stroke engine designers try to keep the crank ( and even the transmission gears) from beign submerged in an oil bath. It takes horsepower to slog thes parts though heavy oil. Thus, lessening the amount of oil that pools at the bottom of the crankcase or gearbox increases horsepower.
Q:
HOW OFTEN SHOULD I CHANGE MY OIL ?
A:
Yamaha recommends changing the oil and oil filter every five rides.
Honda's Eric Crippa advises changing the engine oil as fequently as posssible and changing the oil filter every fifth time. one fo the problems with a fequent service regimen is that it provokes people to use CHEAPER oil.
Q:
CAN I LEARN ANYTHING FROM MY OLD OIL ?
A:
Yes.
Pay careful attention to the condition of the spent oil. If it looks and smells dirty, you need to service it more often. Extend the time between service intervals if the oil appears and smells clean.
High-end race teams , Formula 1 and Reno Air Racers send their used oil out to have it analyzed. Laboratory tests can use a spectograph to determine what metal particles are in the oil - and whether that particel evidence could be pointing towards a potential failure.
This is too expensive and extreme for a local racer, but you should always sift used oil for broken clutch plates , teeth from gearsor any other unusual conditions.
Q:
WHAT OIL SHOULD I USE IN MY FERRARI ???????
A:
Unless you are a factory racer you can skip this question. If you want the best protection for your 360 Modena berlietta, run an Ester Synthetic, API SG, JASO MB, four-stroke, motorcycle racing oil !
  • Similar Content
    • By H0ndaHunter
      Hello all,
      I have a 2005 crf230f im wanting to modify my bike as best as possible for a sumo style bike. My first thought was an engine swap.
      Has anyone done an engine swap on this bike before? If noone has what engine would be the best fit to do so?
      The 230cc engine desnt have enough umph to really be a daily driving unless taking backstreets all the way to work so im trying to see what i can do to make it have the umph.
      Some of the mods ive done include the airbox mod, a lighting kit, sprocket change (i believe i have a 42 and 13 but cant rememebr), and a jetting mod where my dad took the stock jets and drilled it out just significantly enough to make her kick as much as she can.
      Im looking at doing handlebar risers, an airbox mod on the right side of the bike for even more airflow, cr500 shock if possible.
      I am absolutely in love with the turning radius and nimbleness this bike has. I have ridden my dads BRP and my brothers crf450r and they just cant skirt around the world like my bike can so im trying to get the power (hopefully) of a bigger bike in the body of my bike.
      Im not looking to have to completely tear the bike down to modify the bike, but if need i can make it happen. Before i am forced to modify the frame to accept another engine, are there any straight swaps that can happen? Are there any other performance mods that can be done to get that speed a little higher without sacrificing too much reliability?
    • By JMD984
      I have an 03 CRF150F that has a pretty bad wobble in the front wheel.  It has the OEM rim on it, 19x1.40 w/36 spokes.  For some reason, Honda is REALLY proud of their CRF150F rims, and want $125 for a new one.  However, the same size front rim from an XR/CRF100 or CRF125F are only $25-$30.  I realize that the spoke/nipple sizes are different, but is there any reason I couldn't use an XR100 rim and lace it with CRF150F spokes if I drilled the holes out larger?  Could nipple size be an issue?  Center well depth?
      I'm not looking for weight savings, or bling, just a straight wheel assembly.
      Or, if nobody knows the drop-in capability, I sure could use a lesson in spoked wheel compatability.  Does anyone know a good site for learning what features really matter when trying to swap rims?
      Thanks for the insight in advance.
    • By ccasey75
      Looking for BBR upgrades for 2006 CRF230F including the following:
      Heavy fork springs
      Heavy shock spring
      BBR Triple Clamp
      BBR Linkage
      Shock upgrade
      Let me know if what you have and how much you want!!
    • By Christo6060
      They will fit with some modification I did it on my bike 2007. The 2015 through 17 has an extra mounting hole on the tank and shroud so I cut the threads off an extra mounting screw and superglued it in that hole giving it a more authentic look. Except I didn’t use enough glue on the right side and the screw fell out. I had to use spacers on the front mount. And drill a new hole on the original tank mount but that doesn’t effect the original shrouds mounting. And a new hole on the new shroud. The new shrouds also sat correctly against the tank not affecting the seats look. Pictured is the two shrouds next to each other and the bike with the original shrouds. Also pictured is the listing for the shrouds and I only  spent $30 AUD on the OEM shrouds which were listed at $35 after my offer was accepted. They came with new hardware. And it was well worth it. I hope this post was worth the time😂.
    • By Fisforfun
      SOLVED*** No timing issue, just had trouble lining up TDC  Going to rebuild top end to fix low compression. Thanks for the help TT
      So I bought my 2003 crf230f a few months ago from a friend. The bike has definitely been ridden, and was blowing a little bit of smoke when I bought it so I knew the rings would be toast sooner or later. After a basic tune-up the bike ran really strong and I continued to ride it a few times a week for a couple months with no problems... Until last week when I was riding and it died on me. At the moment when the bike died, I was coasting down a hill so there was no extra stress on the engine, I just noticed the engine shut off- almost like running out of gas.
      From that moment on, the bike would not start so I towed it home and checked the essentials... Air, Fuel, Spark, Compression.
      Air- The new air filter I installed when I bought the bike was already covered in dust, so its possible the piston rings got even more dusted. I cleaned and oiled the filter anyway (the bike wouldn't start with the filter removed).
      Fuel- I recently changed my jetting to Mike Coe specs, and installed a larger pilot jet to eliminate popping on deceleration. The bike ran great with the new jetting and I know the carb is clean. I went ahead and cleaned out the gas tank and fuel lines and cleaned out the carb yet again.
      Spark- Spark plug was white due to running lean before I changed the jetting. Plug turned more of a brown color after jetting, indicating better A/F ratio. Replaced spark plug anyway and can see strong blue spark. Also, gas is making it to the plug.
      Finally did a compression test and had low compression. I adjusted the valves which were a bit out of spec, and saw no improvement. A wet compression test (one tsp oil in plug hole) showed higher compression, but still low, indicating the piston rings are toast. I ordered new rings and top end gaskets and will rebuild the top end next week.
      I was also wondering if I have a timing issue, since the engine at TDC (pic 1) shows the cam sprocket about 30 degrees (in the retarded position?) off from being horizontal with the head, as it should be according to the FSM and Clymer manuals. Also, when cranking the engine CCW by hand, the flywheel tends to spin past TDC and happens to align the cam sprocket perfectly horizontal with the head. Is my timing way off? Also, the flywheel has a || mark (pic 2) near TDC that I used to adjust the valves. Just today when I took the pictures, I noticed a |F mark (pic 4) that usually spins past quickly so I never saw it before. both marks appear close to TDC but the engine always wants to spin to the natural position (pic 5). Where is my true TDC? Manuals only show a |T mark. Are the cam sprocket lines supposed to be horizontal with the head? Maybe it jumped a tooth? I have read the cam chain tensioners are known to fail also.
      Edit: Found the T mark, updated photo near bottom of thread
      tl;dr
      Bike died on me, has low compression, going to rebuild top end. See pictures. Could this be a timing issue also? Does anyone know if the lines on the camshaft sprocket are supposed to line up with the horizontal lines on the head? Thanks in advance for the help!
      Pic 1- TDC at || https://imgur.com/QJXXjXH
      Pic 2- || mark https://imgur.com/v7dBSf8
      Pic 3- TDC at |F https://imgur.com/DZCPBaT
      Pic 4- |F mark https://imgur.com/JbcVYhF
      Pic 5- Engine wants to spin to this position: Cam sprocket lines horizontal with head- https://imgur.com/S3rPRgd
      Let me know what you guys think. Has my timing jumped? I appreciate your help!
      Cheers,
      Spencer
      Edit: Finally found the damn "T" mark. Always spins past so I wasn't able to see it before. Updated picture posted near bottom of thread. Timing looks fine so  just going to rebuild top end next week to restore compression
