yz 426/00
my bike over heats when i trail ride any help on what to do to fix my problum.
"Water Wetter" works too. Remember that the water provides the cooling, the antifreeze just raises the boiling point and lowers the freezing point. So make sure your not running more than 50% antifreeze in the radiator. A higher pressure radiator cap may also help...
Do you have any type of after market radiator gaurds? Some of these like the duvall can seriously reduce air flow thru the radiators. If you do you can take a dremmel and cut out every other section to allow more air in.
There could be more of an issue then simply changing the coolant, although it is a good start.
You could have a bad pressure cap, a blown gasket, cracked head or cylinder or maybe the impeller is going bad.
Have you noticed any coolant in the oil, you can tell by smell as well as the oil would start to become milky.
Bring your bike down to a radiator shop and have them test the cap and the system for pressure leaks, may cost you a few bucks.
Check your compression in the bike, check make sure no visible signs of leakage.
I have a 2000 I use a mixture of 50/50 Coolant and Distilled water. I have never over heated the bike.
two last things, dont over fill the radiator. :)
and as stated above, make sure the air flow is good and the fins in the rads are not crushed. Using a small flat head screw drive "CAREFULLY" can correct this.
How are you determining that you're overheating?
thanx for all the help i do have devol gaurds iwill try to open up the holes. thanx again
thanx for the help
If everything checks out o.k. with your engine and cooling system, you can also see some benefits by running "Engine Ice" coolant and I've also had good results with the "Boysen" water pump impeller.
  • Similar Content
    • By PFOS58
      Lightly used Clarke Gas Tank (model #11614) for a 2010-13 YZ450F.  Includes cap.  For fuel injected YZ450F, so needs to have fuel pump transferred over.  Rest of stock tank hardware fits perfectly.  2.8 gallon capacity, so great for desert, hare scrambles, or WORCS.  Retails for $240.
      E-mail me with any questions or offers at billsworld@scinternet.net
      Buyer pays shipping from 84726.
    • By faizakhtar125
      Like this comment if you have a YZ. I want to see how many people have YZ's, especially YZ125's
    • By PFOS58
      ProMoto Billet KickIt kickstand for 2010-13 YZ450F.  Model 5006.  Used, but in good shape.  Buyer pays shipping from 84726.  Will take PayPal.
    • By PFOS58
      Used FMF Factory 4.1 Full Exhaust System. Includes slip-on muffler and two piece header.  Includes approved spark arrestor.  No dings or dents.  Fits YZ450F from 2010 to 2013.  You pay shipping from 84726.
    • By Christopher Harkins
      2009 YZ 250 for sale. Brand new top end, no hours on it. Pro circuit pipe and silencer. No trades. Selling for $3300.
